AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
Old 03-26-2008   #1 (permalink)
TBS Fork tube help
G'day troops,
I am in the process of ordering a set of fork tubes from a US manufacturer for my 98 TBS. I received a call that they actually have a set in stock of a Thunderbird, 43 mm tubes. Their issue is they are unsure if they are TBS or Thunderbird.
My question is:
Even though they are different in their internals, is there any obvious way to verify a TBS tube from a same year Thunderbird tube?
If not, I'll be disassembling my fork to send them the tube to verify and/or reproduce.
Thanks for any help you guys can provide.
Cheers!
blackfly911 is offline   Reply With Quote
Old 03-26-2008   #2 (permalink)
KD5QOQ's Avatar
They don't show the same part number.
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
KD5QOQ is offline   Reply With Quote
Old 03-26-2008   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
They are certainly different
Mick...
Old 03-26-2008   #4 (permalink)
Favorite Bike: '98 Thunderbird Sport - Buford
denny's Avatar
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
I'd be interested in the supplier you are working with to get these replacement fork tubes.
Unfortunately sending him one of your originals is the best way to assure that they produce a proper replacement.
Cheers,Denny
denny is offline   Reply With Quote
Old 03-26-2008   #5 (permalink)
Yes,
I agree, I've started the disassembly process. I'll be mailing them my pitted tube to have a replacement made.
Denny, I'll PM you with details.
Thanks all.
Old 03-27-2008   #6 (permalink)
Almost there,
I've got one of the forks apart surprisingly easily with some great help from the posters here.
One question, at the bottom of the fork tube there is the "bottom bush" it spins in place but seems to be seated, how does one get it out? does it need to be pressed out? The Haynes manual is no help at this point.
Thanks again all.
Old 03-27-2008   #7 (permalink)
Another question,
Dose anyone have the part number for after market springs from Progressive and where's a good place to buy them (online or in store)?
I do find the front end a bit soft under hard braking, I understand Progressives are great replacements.
Cheers!
Old 03-27-2008   #8 (permalink)
jimmyj900's Avatar
My biggest initial problem with my Adventurer was severe front end dive during hard braking.
My solution was to install Progressive Suspension 11-1144 front springs with 5-7/8" PVC spacers and 20W oil.
The airspace above the oil was set at 120mm with the inner tube fully extended and the spring installed. This required almost exactly 1 pint of oil per tube.
That combo may be too stiff for you so you might want to go with 15W oil and maybe a 5-1/2" spacer.
You can then adjust the spacer height with fender washers to where it's what you want.
Dennis Kirk has them Dennis Kirk Part #: 58976, Mfg. Part #: 111144
The DK price is $77.99 so you might want to shop around a bit. The good thing about DK is that they have them in stock and ship promptly.
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 03-27-2008   #9 (permalink)
denny's Avatar
But the TBS forks are different from the rest of the Triple classics, so those springs might not be appropriate. I've not changed mine so I am really no help with this. Just be aware.
Cheers,Denny
Fork Tube Repair bonnieblackinfl Twins Technical Talk 4 12-03-2007 05:10 PM
Fork tube diameter.... GrayMitchell Classic, Vintage & Veteran 3 11-01-2007 08:05 PM
TBS Fork Tube pain. blackfly911 Hinckley Classic Triples 14 09-12-2007 09:19 PM
Fork tube.... NewMetal Twins Technical Talk 0 05-09-2007 08:18 PM
S3 fork tube size? barryd Speed Triple Forum 4 06-02-2006 10:03 AM
