Old 03-23-2008   #1 (permalink)
Alternative to OEM turn signal lens?
Just discovered that the left turn signal lens on the "new" '02 TB I got last Saturday is broken (cracked, and missing a piece of plastic). Is there a less expensive alternative to the Triumph OEM replacement lens? Thank you in advance.
jonathanrsr is offline   Reply With Quote
Old 03-24-2008   #2 (permalink)
Favorite Bike: 00' Legend TT
Eyun_G's Avatar
Check out JC whitney, or any of those places, turn signals are everywhere. Just beware that LED's are going to require in line relays and some other wiring because of the mechanical flasher.
Cooler than the other side of the pillow.....
Eyun_G is offline   Reply With Quote
Old 03-24-2008   #3 (permalink)
thank you
Thank you Eyun,
I'll check them out.
Old 03-24-2008   #4 (permalink)
KD5QOQ's Avatar
The other option is http://www.emgo.com/
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
KD5QOQ is offline   Reply With Quote
Old 03-26-2008   #5 (permalink)
Favorite Bike: Thunderbird
Clear Turn Signals
I replaced mine with clear one I got from Ebay. They are made by Lucas and look very much like the sidelight ones on a Landrover Defender. The fixings are slightly closer together but a 4.5mm drill gives enough of an angle to get the screws lined up.
http://www.triumphrat.net/attachment...9&d=1204452835
mfacer is offline   Reply With Quote
Clear alternative turn signals and the CA law. TattooedRedHead Sprint Forum 2 09-08-2007 05:24 PM
Augh! Dropped my bike..now I'm lookin for a headlight bracket, signal lens & mirror.. Kwocker Hinckley Classic Triples 2 09-08-2007 12:33 PM
'02 ST front signal lens GoCharlieGo Sprint Forum 2 06-30-2007 12:52 AM
Turn signal Lens Soccermasta Twins Technical Talk 8 05-09-2007 05:10 PM
Replacing front turn signal bubble lens on 01 ST EZOUT Sprint Forum 5 11-16-2005 11:39 AM
