Motorcycle.com
Old 03-16-2008   #11 (permalink)
Favorite Bike: 2000 Legend
I know this is beyond obvious, but if it is a non sealed battery, did you make sure it is full of liquid? These bikes tend to boil the fluid out of non sealed batteries. If it isn't full, distilled water will do the trick.
Legendryder is offline   Reply With Quote
Old 03-16-2008   #12 (permalink)
Favorite Bike: Mine! 02 Thinderbird
Paid extra for a sealed "Heavy Duty" battery. Had it charged at the store.
And charged it again here at home last night.
Still nothing.
Keeping the tradition alive for 3 generations.
Grumpymann is offline   Reply With Quote
Old 03-16-2008   #13 (permalink)
Favorite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast ;-)
just because it's new doesn't mean it's any good .
check this thread from a week or so ago http://www.triumphrat.net/hinckley-c...-problems.html
if you have an advanced motor parts store nearby , go buy yourself a sealed AGM battery , size EXT15L .
Woody1911a1 is offline   Reply With Quote
Old 03-16-2008   #14 (permalink)
Still nothing.
I'm not too far from Allentown and if your problems persist and the weather isn't too bad for standing around outside on the street I'd be willing to take a look at it with you.
SlowPocono is offline   Reply With Quote
Old 03-16-2008   #15 (permalink)
Hi,
Try jump starting it. That will tell you if it's the battery.
Steve
Jacksf is offline   Reply With Quote
Old 03-16-2008   #16 (permalink)
jimmyj900's Avatar
Jump Starting -- You can jump start a bike from a car but the engine of the car must not be running. A car alternator can fry the electrical system of a bike!
Starter Solenoid -- The solenoid is a high-power switch that connects the battery to the starter when you press the starter button. Follow the heavy cable from the battery + terminal to find the solenoid. It's located under the bracket that the rear of the gas tank attaches to. Pull back the rubber boot on the terminal and you'll have two 'large' terminals to short across.
If shorting across the terminals causes cranking, then the solenoid needs replacing.
Battery -- It's not impossible that your battery is bad. Charge it and get it load tested at a battery shop or auto parts store. (Walmart can't handle anything that complex. )
Starter -- If the starter has a 'bad spot' you might be able to get it to a 'good spot' by rocking the bike in gear. If that works, then you need new starter brushes at the very least and probably a rebuild.
Jim
CAUTION: This post may have been altered and critical safety information deleted without the permission or knowledge of the author.
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 12:37 AM
i am not dead also convict Twins Talk 22 08-16-2007 10:47 PM
Dead pineygroveshop Tiger Workshop 16 04-08-2007 04:48 PM
Dead Starter on a 2000 Tbird sport. Martiniman2001 Hinckley Classic Triples 5 07-15-2005 09:46 AM
Dead RS Sprint Forum 14 11-04-2004 06:29 PM
