Originally Posted by Mojoinco
Hello all, I want to powder coat my fork lowers, but can't see an easy way to remove the damping screw (other than drilling out what is apparently the retaining pin). Anyone remove there's?
If by 'damping screw' you mean the screw in the bottom center of the lowers...
I've spun those out with an air wrench. Once it breaks loose, there's usually enough friction to spin it free without one of the 'special tools.'
Triumph has a tool to retain the inner damper assembly and as I remember it someone here fabricated one with a piece of rod and a 30mm nut welded on the end.
It depends on which fork you've got.
Jim
