ride height can be altered by both changing the dogbone links to the shocks and by dropping the front forks .
Legend drop links will do the trick. These dog bone looking things on the rear suspension from a legend will lower it 1" & 1/4
Or you can make your own, 1"X1/4" mild steel flat bar. Cut to 8.5"
STock links are 7" centre to centre.
To lower 1 inch holes are drilled 7&1/4" c to c
To lower 1 1/2" 7&3/8" c to c
To lower 2" 7&1/2 c to c
Drop the fork legs through the triple trees a maximum of 5/8"
holes in the drop links are 15/32" diameter.
saved and pasted . i've no idea who to credit for it .
