Site Supporter Moto Grand Prix Favorite Bike: Well, Duh!
Posts: 3,023 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
Why would you want to change them are they chafed or corroded? The 2000 model year had braided clutch and brake lines as stock - these never need to be replaced unless damaged. The Speigler items will not be an upgrade, unless you want a different color.
Its fairly easy to remove the clutch line - but you need to remove the tank to do it. It is also notoriously a pain to bleed all the air out if you do replace it, but there is a knack (ask here for help if you do this). And don't get the fluid on the paint!
Mick...
