Motorcycle.com
Old 03-13-2008   #1 (permalink)
Favorite Bike: 2000 Thunderbird
Wordguy's Avatar
Replacing the clutch hose
I am going to replace my brake lines with new ones from Spiegler. I'm thinking I might replace the clutch hose also. Is it difficult to remove. It looks like it snakes around behind the cylinders.
Spiegler doesn't carry a Tbird clutch line as a standard item, so they want me to send mine in so they can match it. How of the engine do I need to monkey with to get the hose off?
Thanks,
-Alan
Wordguy is offline   Reply With Quote
Old 03-13-2008   #2 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Why would you want to change them are they chafed or corroded? The 2000 model year had braided clutch and brake lines as stock - these never need to be replaced unless damaged. The Speigler items will not be an upgrade, unless you want a different color.
Its fairly easy to remove the clutch line - but you need to remove the tank to do it. It is also notoriously a pain to bleed all the air out if you do replace it, but there is a knack (ask here for help if you do this). And don't get the fluid on the paint!
Mick...
Old 03-13-2008   #3 (permalink)
Wordguy's Avatar
These are the original lines, and the Big T recommends they be replaced every four years. (It's a 2000 Tbird.) On the clutch line, the master cylinder banjo bolt has a bit of corrosion.
I had (still have) a ton of trouble bleeding the brakes. I hope the clutch would be that bad. I think the issue is that the brake pistons are gummed up. I am going to take it to the dealer as I can't seem to get enough time to mess with it.
-Alan
Old 03-13-2008   #4 (permalink)
The recommendation is a hangover from the first T3 classics that had rubber lines on the brakes - I would not bother changing unless you want to fix that corrosion (which might be rectified with the careful application of a little paint)
Mick...
Old 03-13-2008   #5 (permalink)
Wordguy's Avatar
Cool. Good to know. I could maybe just put in a new banjo bolt. I'll look at it more closely.
-Alan
Old 03-14-2008   #6 (permalink)
a new banjo bolt would result in the need for a bleed - but would be a cheap fix
Mick...
Where's the hose? oldyeller Daytona Deliberations 8 08-26-2007 11:54 PM
What is this hose??? SDFOUR Triumph SuperSports 1 12-30-2006 07:39 PM
hose that's not connected PtboSprintSt Sprint Forum 4 10-11-2006 12:23 AM
Replacing clutch cable harum-scarum Tiger Workshop 20 03-20-2006 08:05 AM
HOSE / mystery hose bonnieamer1 Twins Talk 8 09-11-2005 01:04 AM
