Old 03-11-2008   #1 (permalink)
Carb Problem Solved!!!
So I was having trouble trying to remove the needle valves from 2 of the carb banks. They were all gummed up with this heavy green corrosion. Strange thing is, the left carb (the one that has the idle adjuster on it) was Completely clean! The other carb banks werent really dirty either... It was just this thick green stuff on 2 of the valves.
I figured I would post pics and explain how I removed them in case anyone comes across this issue in the future.
First, soak for a while with carb cleaner.
Then I gently tapped the back of the valves to try and jolt them loose. It didnt seem to work but maybe it helped loosen them up a bit.
I then got a tiny flat head screwdriver and stuck it in the groove at the bottom of the valve where the clip locks in and I used another screwdriver as leverage and eventually got it out. I did have to get a bit aggressive but I didnt really see any other choice. This stuff was caked on there good.
FrankD is offline   Reply With Quote
Old 03-11-2008   #2 (permalink)
PS- I know it doesnt matter anymore... but does anyone have ANY idea why 2 of the valves were so clogged up. while the other one was immaculate? I asked the original owner and he said he never had any carb work done.
Old 03-12-2008   #3 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
...possibly something to with the bike leaning to the left while on the side stand....
gregp is online now   Reply With Quote
Problem Solved TrackerOldGuy Speed Triple Forum 7 05-25-2006 09:33 AM
Idle problem solved rktmn3 The Rocket Science Forum 6 03-09-2006 06:47 PM
Kickstand problem solved? HDRocket The Rocket Science Forum 1 07-21-2005 10:38 AM
Helmet visor cleaner problem solved!!! Timtiger Modifications & Workshop Talk 23 07-12-2004 10:28 PM
Solved the starting problem! T3 Sport / Touring Forum 6 04-02-2004 08:58 AM
