Old 03-05-2008   #11 (permalink)
jimmyj900's Avatar
Originally Posted by IrlMike View Post
I'd read about the needle & needle jet wear & took a look at Factory Pro's site info. The original needles were showing signs of wear. I looked at the needle jets under an illuminated desk magnifier & they +seemed+ ok, so I put in new dynojet needles & hoped I'd be ok - looks like wasn't. I guess you are confirming that ?
Well, I can confirm needle jet wear as a problem on the Mikunis but not having seen your jets or needles I can't say that's your problem. There's also a problem with wear on the plastic slides that I think may account for some of the needle rubbing, but I can't verify that since I don't have a set of Miks to play with.
Feeling a bit loathe to be buying new parts for these mikunis to last how long (?), I took a look on ebay & my luck was in, just bought a set of Keihins off a legend for ~ $150 .
The Keihins are better built than the Miks and much more durable. I'm there's a difference in the inlet and outlet diameters so you'll have to change to the rubbers for a 2000 model, but that's the only installation difference I'm aware of.
I'm thinking I should be ok with stock jetting for now on the Keihins with K&N in stock airbox & thunderbike 3-1, but looking at your previous posts (& others too) I think I'll want to play later with some mods & factorypro or thrux needles
You might want to go up a step (98 to 100) on the main jets, but don't bother with the Thruxton needles unless you change the cams. It will be too rich on the bottom end otherwise.
BTW, you recall I was having carb setup problems with tickover speed ? Turns out the tach was faulty, high by 3/400 rpm - now have a trophy clock set (ebay 40 bucks! -complete with water temp gauge) & no probs carb setting..
Cool!
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 03-05-2008   #12 (permalink)
Favorite Bike: '99 ThunderLegend Special
IrlMike's Avatar
Cheers Jim ! As ever, the lowdown
IrlMike is offline   Reply With Quote
carb help misfire when warm hodgy T3 Sport / Touring Forum 7 02-05-2008 07:20 AM
Carb tuning after rebuild. Ahobie17 Classic, Vintage & Veteran 5 12-20-2007 02:05 PM
Another carb tuning question quagmire Classic, Vintage & Veteran 30 09-11-2006 05:06 PM
Carb tuning PoiDog Twins Technical Talk 16 08-22-2006 08:37 PM
carb jetting and tuning Mclaren58 Daytona Deliberations 2 03-21-2006 05:08 PM
