Triumph Legend Starting problems
I have a 1999 Legend that is hard starting cold. You literally have to crank it for 120 or more seconds to get it to start. I have tried full choke, partial choke, no difference. When it does start it runs perfect and idles smooth. Once the machine is warmed up it only requires a touch of the starter to get it going. It will never start cold with the starter button depressed. It seems to light off the second I release the starter, almost like it doesn't get spark when the starter is engaged. The bike runs perfect once it is running, no stumbling, no flat spots, smooth idle.
Have there been any reports of ignition module failure? The problem goes away when the engine is at operating temperature.
Regards,
Gary
