swing arm removal - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-26-2008, 06:51 PM   #1 (permalink)
Favourite Bike: 96 T-bird
wolfd123's Avatar
swing arm removal
Despite diligently looking through the shop manual as well as related posts here I have yet to determine why the swing arm will not come off. I have removed everything per the manual up to and including the swing arm spindle, however the swing arm will not pull off as it should.
Any Ideas?
wolfd123 is offline   Reply With Quote
Old 02-26-2008, 07:07 PM   #2 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Try using the search function.
I did and found this from a week ago:
http://www.triumphrat.net/hinckley-c...m-removal.html
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 02-26-2008, 09:44 PM   #3 (permalink)
wolfd123's Avatar
Got it
Ya, I saw that one before but it didnt really give me the info that I wanted, which was permission to start wrenching the swing arm away from the bike. After messing around for about a hour or so I got tired of poking at it and used a small pry bar pull it off. Worked great after I gathered the courage to start.
Once again the manual was right on the money, I just had to follow the instructions...
Cheers
Wolf
Old 02-27-2008, 08:52 AM   #4 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
On most of the bikes that I have had to remove the swing arm on, I have found it very useful to loosen any motor mounts, fender mounts, or other points of mounting, that might be "pinching" the frame together. Swingarms usually fit very tightly between the items that they are intended to contact. Also, the bearing sleeves, or seal caps can work a small recession into their neighboring steel counter parts, either in just the paint, or into the actual steel itself, making removal seem impossible. If you are absolutely positive that you have released all parts/pieces necessary, start applying force, in small quantities at first, ramping it up until the arm breaks free.
gregp is offline   Reply With Quote
swing arm fasteners JonahP Street Triple Forum 14 02-18-2008 05:22 AM
How To Tell if I have a Triumph Swing Arm MNTriGuy Classic, Vintage & Veteran 2 12-18-2007 07:15 PM
Swing Arm .... NewMetal Twins Technical Talk 4 05-09-2007 05:24 AM
TT600 Swing Arm Removal - Help Needed MarkTheBike Triumph SuperSports 5 05-02-2005 05:37 AM
Swing Arm & other bits bigD Tiger Mods & Bolt-Ons (archive) 5 04-26-2005 01:20 PM
