Old 03-01-2008   #11 (permalink)
Favorite Bike: jury is still out
Other Motorcycle: 98 Adventurer
Extra Motorcycle: 80 kz650 kawasaki
I had the same problem with a Kawasaki concours. I took a deep well standard socket and put it in a lathe and turned it thinner. Quick easy job if you know someone with a lathe.
Bbogie is offline   Reply With Quote
Old 03-01-2008   #12 (permalink)
When you go to put the new plugs in ,I have found a short piece of split fuel line gives good feel to get it started straight b4 the socket goes on,also a good strong magnet is helpful if socket comes off and drops and is hard to reacquire with extension
idjk is offline   Reply With Quote
Old 03-02-2008   #13 (permalink)
Favorite Bike: 06 Sprint ST ABS
Garyhjd's Avatar
Other Motorcycle: Legend TT
I use fuel line to get the spark plug started (learned that working on Alfa's) then tighten with the spark plug socket.
The Ace Hardware socket also fits, tried it as well, kept the craftsman less cost not made out of country.
gary
Garyhjd is offline   Reply With Quote
Old 03-02-2008   #14 (permalink)
Favorite Bike: '99 ThunderLegend Special
IrlMike's Avatar
my 2 cents ...
bought a spark plug socket, good quality, even has +metal+ spring clips inside to hold the plug, ground it down with angle grinder to fit hole (actually did this years ago for a different brand of m'cycle, but had to get the grinder out again for the Tbird!)
this is a 1/2 drive socket, so I fit a 3/8 drive adapter & a 3/8 universal joint (no other kind- you'll get the bike wrong way up & still be laughin' )
this gives just enough height to attach a ratchet bar (3/8) & enough 'flexibility' to remove or insert any of the plugs....
IrlMike is offline   Reply With Quote
Old 05-11-2008   #15 (permalink)
polex's Avatar
Other Motorcycle: Kawa ZR-7S
Extra Motorcycle: Honda CBF600
Craftsman 50728
I bought CRAFTSMAN 50728 18mm spark plug socket.
I noticed that the rubber cams cover gasket adhere to the socket in the spark plug cavity, preventing a free socket movement.
I think that It should be very difficult to remove the socket after mounting the spark plug.
I have a new NGK spark plug but I still use the Champion spark plug because I didn't found yet the right 18mm socket.
The Champion spark plugs require a 3/4" socket for removing.
Originally Posted by Wombat View Post
This one from Sears is reported to work:
http://www.sears.com/shc/s/p_10153_1...43330&sLevel=0
Is the external diameter of the model# 43330 smaller than model# 50728 ?
polex is offline   Reply With Quote
Old 05-17-2008   #16 (permalink)
Favorite Bike: 1998 Thunderbird Sport
Spark plugs
I have 2 different 18mm sockets from Sears, both the laser etched, and the non, and one from Ace, and one from Auto Zone, none of which fit in my '98 TBS...eventually broke down and bought the original from BikeBandit.com that comes in the tool kit ($18.50 ish) Never thought about shaving it down though, i'll bet that would work well! Also, as far as retrieving the socket once the plug is installed, I found a pair of 90 degree needle nose pliers work great.
tornado TBS is offline   Reply With Quote
Spark Plug Socket EdC Hinckley Classic Triples 4 09-07-2006 07:52 PM
what socket for spark plug removal? sweatmachine Twins Talk 4 06-09-2006 05:22 PM
Spark Plug Socket Anchorbend Twins Talk 1 03-01-2006 09:02 PM
Spark plug socket size darktolight Twins Talk 0 01-28-2006 06:35 PM
Spark plug socket? Modifications & Workshop Talk 4 02-09-2005 10:57 AM
