Originally Posted by Tbird96jk
I've been told the single seat from the 96TBS will not fit, and I don't want to order something if it isn't going to work.
Not sure that's true, actually. If you have the locking-style seat (which the '96 T-Bird does, IIRC) then you should be able to get the solo seat to fit (though you may need to move the locking mechanism to a different position, and and modify the rubber spacers under the seat). I'm pretty sure others have done this mod, if you search around the forums.
Corbin also makes a solo-style 'gunfighter' seat for the earlier (locking) T-birds.
Beyond that you'll have to get creative. You can send your stock seat to Sargent and have it re-shaped and re-covered, you can buy something off eBay and try to make it work - AFAIK there's nothing that's a bolt-on mod.
Look around the forums, there are lots of people who have done it.
HTH.
