For Forks Sake - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleHonda Powersports
Old 02-19-2008, 10:11 PM   #1 (permalink)
Petrol's Avatar
For Forks Sake
My Thunderbird has a drippy fork seal.I`ve never changed one .Any hints or tips?,parts are on order.
Petrol is offline   Reply With Quote
Old 02-20-2008, 09:18 AM   #2 (permalink)
Favourite Bike: 95 TBIRD
patrol21's Avatar
Hey petrol,
Check out the threads for good info. I have had my front end of 3 times over the last few years. A couple of tips
1) Use OEM seals....the extra few bucks is worth it.
2) makes sure you have "0" nicks, dings on the tubes. I had a couple and after a couple of seal changes within 5K, I replaced...no leaks since.
3) Not a hard job but there is one tool that you cannot do this job without. The dampening rod is held in place near the base of the tube and you must be able to loosen this. You can order a tool from triumph but it's expensive. I found a brass cap (six sided) that I was able to insert into a steel rod (aprox 3 ft). This fits into the head of the dampening rod and holds it while you spin the tube. This breaks it loose from it's threads.
4) When seating the oil seals, Triumph reccomends using another special tool.....I found that a piece of PVC pipe also works nicely. Hell, the last time I took apart a fly rod holder as it was the perfect diameter to drive the seal. As long as you are uniform with the pressure. Just don't try to seat it unevenly.
5) If you think the front ends are a bit spongy, kick up the oil weight. Progressive springs are the next step and not that expensive.
good luck
The worst day riding beats the best day at work....no exceptions.
patrol21 is offline   Reply With Quote
Old 02-20-2008, 12:22 PM   #3 (permalink)
KD5QOQ's Avatar
"Not a hard job but there is one tool that you cannot do this job without. The dampening rod is held in place near the base of the tube and you must be able to loosen this. You can order a tool from triumph but it's expensive."
I have done this with a 3/8 impact. It spins the bolt fast enough that a tool is not needed.
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
KD5QOQ is offline   Reply With Quote
Old 02-20-2008, 12:27 PM   #4 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
I have also used a broom handle (!) for this job. Just use a broom stick and whittle the end down to a taper, then stick the tapered end down into the end of the damper rod (from the top of the fork tube). Tap it a few times with a hammer or tap the entire assembly (upside down) on the floor, to get the wood to comform to the shape of the hex inside of the damper rod. This is usually sufficient to hold the damper rod from turning while you loosen/ remove the bolt at the base.
I know that it sounds crude, but it works!
gregp is offline   Reply With Quote
Old 02-20-2008, 12:31 PM   #5 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
I too have used greg's brom handle method - it works ok.
Spinning it out with an impact wrench doesnt always work especially if the loctite binds
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 02-20-2008, 03:25 PM   #6 (permalink)
Favourite Bike: '99 ThunderLegendSprint
IrlMike's Avatar
Other Motorcycle: Wouldn't mind a Tiger 800
Extra Motorcycle: Can't ride more'n one...
Didn't need the tool either to hold the damper rod bolts, left forks assembled & tackled these first, just loosening at this stage. My allen key just turned round in the heads tho' with hardly any pressure. Hammered in the nearest torx size to get some grip & used impact driver - no problem, could probably have used the (now) torx bolts again! - but didn't .
The copper washers on the bolts seemed to be a bit oversize & had trouble removing bolt & washer once I had the fork off the bike. Bit tricky pushing the bolt out from the top....Clipped the washers to smaller outside diameter & reused - no leaks.
BTW, fitting Racetech cartridge emulators was my reason for diassembly - rate this mod AA++
Hope the job goes well for you.
IrlMike is online now   Reply With Quote
I hope for Brent's sake... d2mini Biker Hang-Out 31 01-17-2008 11:31 PM
For Goodness Sake yoda Sprint Forum 10 07-28-2007 09:41 PM
'67 forks TomThomson Classic, Vintage & Veteran 3 02-28-2007 09:17 PM
Forks? Merrimac Speed Triple Forum 6 10-27-2006 12:05 AM
OH FOR FORKS SAKE!!! bigred900 Hinckley Classic Triples 8 07-23-2006 09:09 AM
