02-16-2008, 09:11 PM
SuperStock Favourite Bike: 2K T-Bird
Posts: 215 Other Motorcycle: '98 900 Trident Extra Motorcycle: '85 Nighthawk
Cleaning a K&N
I finally got into the long-awaited carburetor mods this afternoon. I'll know tomorrow how badly I've screwed my bike up.
But in the meantime, I'm looking to clean the K&N filter, which is kind of greasy and gross in one corner. K&N tells me that the one and only way to clean their filters is with a special filter cleaning solution which I can only purchase from them.
Does anyone know of another way to clean these filters without damaging the element--preferably with something cheap and commonly available?
02-16-2008, 09:25 PM
SuperSport Favourite Bike: 2000 Adventurer
Posts: 1,038 Other Motorcycle: 67 T100C Extra Motorcycle: Buell Blast
just bought a k&n recharge kit at my local jap bike dealer . cleaner and oil . the cleaner bottle says it contains " disodium metasilicate" . whatever you do , do NOT induce vomiting
02-16-2008, 09:29 PM
Administrator
Site Supporter SOTP Vintage Series Favourite Bike: '04 Thunderbird Sport
Posts: 7,617 Other Motorcycle: I wish!
How would you induce your air cleaner to vomit if you had to?
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
02-16-2008, 09:37 PM
make it watch another briteny spears newscast ?
02-17-2008, 04:29 AM
Newbie
I just picked up a K&N recharge kit at NAPA. It was about $20 and included the cleaning solution as well as the filter oil. Should be pretty easy to find and available most anywhere, and a lot cheaper than replacing damaged filters.
02-17-2008, 09:49 AM
Formula Extreme Favourite Bike: 1996 Adventurer
Posts: 589 Other Motorcycle: 2000 DRZ400-S Extra Motorcycle: '99 Ninja 250,'04 KDX200
I have cleaned K&N filters with brake cleaner before. No damage was noticed. You can spray it right through the element and wash it out pretty good. It also evaporates pretty fast. The "Grease" you are noticing is the result of over oiling. I would, however, recommend using K&N filter oil as opposed to foam filter oil, on the K&N, as the K&N oil does not "Tack up", which allows it to weep through the fibers evenly. It takes very little oil to get a K&N filter properly oiled. It just takes some time for the oil to wick itself around the element.
02-17-2008, 10:19 PM
Please just go buy the right stuff & don't screw he filter up.
Be aware, what YOU may think needs cleaning, in most likelihood doesn't.
This is a direct quote from K&N, take special note of the sections highlighted in red below.
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
02-19-2008, 11:02 PM
I have a question. After cleaning the K&N oil is applied. If next cleaning is 25,000 miles, and assuming that takes 2 years, would not the oil dry out?
Cheers
Cat
02-20-2008, 01:10 AM
Cheers
Cat
No....Oil doesn't evaporate!
I sold K&N's for almost 10 years when I lived in the UK...hence the advise.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Cleaning
shane |
Sprint Forum |
19 |
09-17-2006 02:45 AM |
Cleaning...
Noumenon |
Maintenance & Workshop Talk |
4 |
08-15-2006 04:22 PM |
cleaning
Celt |
Speed Triple Forum |
4 |
05-31-2005 08:36 PM |
Cleaning
drno5150 |
Sprint Forum |
10 |
05-03-2004 02:27 PM |
