The Nology coils are a direct bolt-in replacement except for the high voltage connection.
If you're using the Nology plug wires it's no problem, but if you're using the Triumph plug wires it requires a bit of modification and replacement of the connector at the coil end.
Let us know if you need info on modding the wires.
Jim
