Thunderbird Sport Swinging Arm Removal - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-13-2008, 01:42 PM   #1 (permalink)
Favourite Bike: Triumph Thunderbird Sport
Keithiopian's Avatar
Other Motorcycle: BMW R60/6
I am trying to remove the swinging arm on my 1998 TBS. I have removed the wheel, chainguard, brake torque arm, mudflap, disconected the suspension linkage, and removed the large swinging arm bolts on both sides. What now? I am working from a Haynes manual, but my bike bears little resemblence to any of the photographs or exploded diagrams. The manual shows spring clips and talks about removing swinging arm inner sleeves(?). The swinging arm spindle in the manual appears to be a solid item. Mine is tubular. According to the manual, I should be able to drift the spindle out. I am reluctant to start slogging away until I know I have done everything right. Anyone removed theirs before?
Keithiopian is offline   Reply With Quote
Old 02-13-2008, 03:28 PM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
Most likely its a little stuck with corrosion. I'm a little intrigued as to why you should want to do this? Are you trying to remove the swing arm or just the pivot (to lube the bearings)?
IIRC there are factory tools for reassembly / keeping everything in line while you remove the pivot for the lube job. If you don't have the tool you might end up in a bind. Not bothered to do mine yet so can't be sure.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 02-13-2008, 04:42 PM   #3 (permalink)
I need to remove the swinging arm to do a thread repair. Since I bought the bike one of the chain adjuster bolts was always stiff. As I was overhauling the brakes I thought I might as well see what the problem was. The bolt was siezed solid. In trying to remove it, it snapped. I really don't want to remove the swinging arm, but I'm afraid I have no choice.
Old 02-13-2008, 05:21 PM   #4 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
I know that there are "Repair Kits" for this problem. They are popular in the dirt bike sector as this is a recurring problem on many dirt bikes. I have repaired 2 Husqvarna's myself, using a long drill bit and the appropriate tap with an extension. Most can be repaired without removing the swing arm.
I will post a link if I can find one.
Edit - Here is one:
http://www.rockymountainatv.com/prod...dFamilyId=2663
gregp is offline   Reply With Quote
Old 02-13-2008, 05:36 PM   #5 (permalink)
That sounds like a good idea. Unfortunately nothing is ever easy. My bike is in a garage with no access to a power supply.
Old 02-15-2008, 01:52 AM   #6 (permalink)
Favourite Bike: the only one i've got..
entropy's Avatar
i pulled mine a couple years ago by just following my haynes manual. as far as i remember it was pretty straight forward. my spindle is solid with a threaded bolt just as illustration 15.1 on pg. 6*24. fyi, now is a good time to replace your drive chain slider.
patrick
my 1998 cafed tbs
WTB: black crank cover for a Thunderbird Sport.
entropy is offline   Reply With Quote
Old 02-15-2008, 02:01 AM   #7 (permalink)
entropy's Avatar
as far as spring clips... the way it's written is funny. that actually pertains to the sprint executive and trophy models from vin 29156 models. the inner sleeves i believe just come out with the spindle.
patrick
my 1998 cafed tbs
Old 02-27-2008, 12:27 PM   #8 (permalink)
Well I've just about given up. As I say, my swinging arm is nothing like the one in the Haynes manual. Mine is tubular, with seperate threaded pieces in each side of the frame. The threaded pieces seem to be pressed into the frame. I can see no way of removing them. I am now trying to think of a way of bodging the chain adjustment. I can honestly say that in 29 years of riding bikes I have never come across any motorcycles which are as difficult to work on as Triumphs.
Old 02-27-2008, 01:05 PM   #9 (permalink)
Favourite Bike: 96 T-bird
wolfd123's Avatar
drift it out
Sounds a lot like the swing arm on my 96 t bird. I was also reluctant to drift the pin out of the swing arm housing. I loosened all of the frame to motor connections and then used a hammer and a piece of wood dowel to get the pin started out of the left side. If it is anything like mine the right side is a nut and the left side is the pin.
Good luck
wolfd123 is offline   Reply With Quote
Old 03-01-2008, 09:15 AM   #10 (permalink)
I have now bought a disc of the triumph microfiche. My swinging arm set-up is completely different from every version of Thunderbird on the disc!
will a thunderbird tank fit a thunderbird sport? aeycue Hinckley Classic Triples 15 10-23-2009 06:42 PM
Swinging arm nut cover dickieshep Sprint Forum 10 08-17-2007 06:38 AM
chain adjustment 595 955 98 swinging arm eytriumph64 Maintenance & Workshop Talk 5 01-13-2007 03:49 PM
TT600 Swing Arm Removal - Help Needed MarkTheBike Triumph SuperSports 5 05-02-2005 05:37 AM
Swinging arm bush renewal Doublespin Classic, Vintage & Veteran 0 12-23-2004 08:16 AM
