Chain/Sprocket Replacement
In respect to the chain, go for quality regardless of price! Like engine oil, there are many opinions as to which make is the best. For what it is worth, I am a DID fan and fitted a 50VM X ring chain. Only time will tell!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
JT sprockets seem to get a good write up. Replaced both of mine with these and went up one tooth (to 18) on the gearbox sprocket. The OEM sprocket has a band of rubber around both sides of the gearbox sprocket which the JT does not. This rubber is designed to 'cushion' the chain around the sprocket and absorb any noise. The lack of it seems to make no difference.
Also fitted a Loobman Oiler to extend chain/sprocket wear. So far, so good!
