Carb balancing - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Honda Powersports New BonnevilleMotorcycle.comOntario Tourism
Old 02-11-2008, 05:19 PM   #1 (permalink)
Carb balancing
Hi guys
Just 2 quick questions before I take my TBS to bits.
When you take the carb bowls off to get to the pilot jets, do I need to replace the o rings. Yes I know we should, but in your experiences am I likely to get away with it?
Also when purchasing vacuum gauges to do the balancing, does the rubber hose between gauge and carb just push on? It's just that the website talks about 6mm and 8mm adapters.
Thanks
Tomsdad
tomsdad is offline   Reply With Quote
Old 02-11-2008, 08:43 PM   #2 (permalink)
jimmyj900's Avatar
Which carbs do you have?
The Mikunis are pretty sensitive to overtightening of the float bowls (since there are only two screws) and have a bunch of o-rings that you should replace considering the age.
The Keihins have four screws holding the float bowls and if you're gentle with the screws you won't need to replace the gaskets. I've had mine apart so many times the screws wore out, but there's no leakage from the float bowls.
Jim
Old 02-13-2008, 05:01 AM   #3 (permalink)
Favourite Bike: Triumph Thunderbird 2003
muchelneybandit's Avatar
Other Motorcycle: Suzuki GSX400 1981
Keihins
I have Keihins and I just put the rubber hose straight on the studs to balance.
The adapters are for carbs that have threaded holes with a bolt in them to keep the vacuum when not being used.
muchelneybandit is offline   Reply With Quote
Carb balancing vol245 Twins Talk 32 09-24-2007 09:44 AM
carb balancing BlueJ Twins Technical Talk 15 09-03-2007 03:55 AM
carb balancing elDizzle Club Cafe' 2 05-23-2007 07:16 PM
Carb Mixture Adjustment/Carb Balancing pweitz Twins Talk 7 03-13-2006 01:54 AM
Carb Mixture/Carb Balancing pweitz Twins Talk 7 02-08-2006 10:31 PM
