Originally Posted by tomsdad
From the feel of the problem - my first thoughts are blocked pilot jets? It just feels like petrol starvation.
If it was ignition probs, why would it happen only at low revs?
Could the cabs need bancing?
Pilot jets clogging is a standard problem with the Keihin carbs and a bike that's been sitting too long.
Remove the pilot jets, hold them up to a strong light and examine them with a good magnifying glass. The bores should be shiny and 'machined' looking. If they're dull and 'organic' looking then they need cleaning. Soak them in solvent/brake cleaner/carb cleaner and scrub them out with some small gauge stranded copper wire since that won't scratch the brass.
Ignition coil problems will show up at low rpm (under 3000) because the bike is running on the battery at a lower voltage than when the alternator kicks in. A low input voltage to the coils shows up as a low spark voltage on the output.
Carbs ALWAYS need balancing!
Jim
