Old 02-10-2008   #1 (permalink)
Newbie
popping at idle & running rough
I need to know what the ohms should be when testing the coils?
jh1498 is offline   Reply With Quote
Old 02-10-2008   #2 (permalink)
Favorite Bike: 96 Adventurer
I beleive it should be 10. Try testing them when they are hot to see if you have one going bad. When they are cold they may test ok. I am having the same problem with my 96 Adventurer iratic Tach when running also.
I am purchasing Nology coils.
Corey
AKMCDM is offline   Reply With Quote
Old 02-10-2008   #3 (permalink)
jimmyj900's Avatar
The resistance on the primary side of the coil is 0.63 ohms and the manual gives a 10% tolerance.
The secondaries of the coils are difficult to measure since there's a pair of diodes in series with the winding and you need a volt/ohm meter that puts out greater than 1.5 volts when in ohms mode. Not many meters will do that.
The best test for the coils is to hang a spark plug off the coil high voltage lead, ground the big end to the chassis or engine case, and then crank the engine.
A fat blue spark says you're OK but a thin yellow (or no) spark says that either your ground to the spark plug is bad, the coil has failed or your battery voltage is low.
Jim
rough idle jonno1953 Twins Technical Talk 10 11-14-2007 02:56 PM
Rough idle htown16 Classic, Vintage & Veteran 7 07-25-2006 08:46 PM
2001 thunderbird running rough at idle and takeoffs shedds Modifications & Workshop Talk 1 08-20-2004 09:48 PM
Rough Idle OlyKen Sprint Forum 4 07-12-2004 04:03 AM
Rough Running ST Sprint Forum 7 02-08-2004 04:59 PM
