Front Forks For 99 Legend - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-09-2008, 11:55 PM   #1 (permalink)
Newbie
Question Front Forks For 99 Legend
New Member Here, Will The Zzr1200 Forks Bolt On With-out Any Modifications To The Triump Neck.
hogrunr is offline   Reply With Quote
Old 02-10-2008, 06:47 AM   #2 (permalink)
Métisse's Avatar
They will fit to the Triumph neck, both 43 mm, but they are to short to fitt in a Tbird. I know for sure, a pair of ZZR forks eating dust in my garage . If the forks of a Legend are shorter, I don´t know, i dont think so, Legend height is less than Tbird but fare as I know it´s because the 17 inch frontwheel (Tbird 18) and the different subframe.
Is this question because you will use twin discs? See postings about the Trophy brakes overhere.
Métisse is offline   Reply With Quote
Old 02-10-2008, 06:42 PM   #3 (permalink)
Newbie
99 legend front forks
i like the way the heavily modified triumps are going and wanted to try something like that. double disc would be nice. the forks you got collecting dust are they in good shape and if you what are you asking for them. thanks for the first reply
Old 02-11-2008, 10:44 AM   #4 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
How much shorter Metisse? I fitter ZRX forks, they were shorter but worked fine.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 02-11-2008, 05:38 PM   #5 (permalink)
Métisse's Avatar
Hi Mick,
ZZR 1100 forks are 30 mm shorter dan the ZRX ones,
so a bit too mutch in my opinion with original Tbird ones. (25 mm. longer then ZRX I thought)
Are you using the original ZRX springs?
How it all will work, don´t know before spring.
As you see on my picture in the brakestopic, still working on it, had to buy an other hub because i screwed the one you see on the picture
When it is arriving some work had to be done (has to be more careful) and then a specialist overhere in Holland will spoke it as well as the rear one (5.5 x 17)
Old 02-11-2008, 06:00 PM   #6 (permalink)
yah, sounds a bit short to me. I dont think I would want to go shorter than the ZRX without lowering the rear.
I have race-tech springs in mine - never tried the stockers, but I'm sure they would have been an improvement over the sponge-cake Triumph front end
Mick...
Old 02-11-2008, 06:43 PM   #7 (permalink)
Métisse's Avatar
Mick,
I will try first the original ones, beleve they are fitted, don´t know for sure.
The ZZR fork came with the bigger brakecilinder and the frontaxe for 100euro (beleave about 75 dollar) so it was cheap and will sale it once
ZRX forks was just the pare of it, so could use the axe and mastercilinder
Greetings
Matthy
USD Forks on a Legend - an Epic Tale crosstie Maintenance & Workshop Talk 6 05-06-2009 12:01 AM
front forks Trumpet D666 Twins Technical Talk 0 09-21-2007 05:42 PM
Front forks mshelton Club Cafe' 18 03-10-2007 11:42 AM
Front forks mikey Sprint Forum 2 08-26-2006 01:00 PM
front forks Haggis Sprint Forum 5 06-16-2005 05:12 PM
