BikeBandit
Old 02-09-2008   #1 (permalink)
Favorite Bike: triumph trophy 1200
Other Motorcycle: triumph thunderbird
Extra Motorcycle: honda cb750
trophy brakes
ok...anybody out there know if the stock brakes from a 1999 triumph trophy 1200 will fit on a 1998 triumph thunderbird? and if they do fit, will there be any improvement over stock? i am going to put some hayabusa front calipers on my trophy and i thought the "triumph" stamped on the stock trophy calipers would look pretty slick on the thunderbird. anyway...anybody got any input on this?
well done is better than well said
jpweddle is offline   Reply With Quote
Old 02-09-2008   #2 (permalink)
Favorite Bike: '98 Thunderbird Sport - Buford
denny's Avatar
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
They won't fit the Stock TBird forks.
but if you put forks from a T3 Trophy, Sprint, Daytona or Speed Triple.
Then you'll need a Wheel that has mounts for dual discs.
Wheel from same bike as forks.
Or maybe a TBS wheel (good luck finding one) if you want spoked wheel.
You'll likely need to have one or two custom spacers made.
Not impossible, but not exactly simple either.
Cheers,Denny
denny is offline   Reply With Quote
Old 02-10-2008   #3 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
Just a couple of extra points, to add to denny's good post, and looking at it as a possible straight "bolt-on".
I think you will find the Thunderbird mounting holes are 85mm, whereas on your Trophy they are 90mm?
The Thunderbird's caliper is a 2-pot sliding caliper with both pots on one side. The Trophy's caliper is a fixed 4-pot caliper with 2-pots either side, and having 2-pots either side the (Nissin) design is broader and a problem for the spokes. There are 4/6-pot fixed caliper designs (Beringer/Harrison/Pretech) which are slimmer and can safely be fitted with the spoke wheels, and have the 85mm fixing. However, if going for a fixed caliper then the rota/disc should be changed to a floating type, from the solid currently on our Thunderbirds.
Hope these extra bits, with denny's post, helps?
Geoff
GeoffE is offline   Reply With Quote
Old 02-10-2008   #4 (permalink)
Métisse's Avatar
The Hayabusa calipers are the 6 pods?
Then you could better use ZRX forks and 310 mm Kawa discs. It depends one wat kind of wheels you will use.
I am building something like that after seeing the MickMaguire Tbird overhere.
Mick is using the wheels of the kawa ZRX too but i will use spocked wheels because i find it more classic, specially when the Tbird is black.
The Hayabusa pots are a bit different then Kawa one´s. They use 8mm bolts and the kawa ones are 10 mm to bolt the calipers on the fork.
A spocked TBS wheel is hard to find, a new one is verry exspensive (about 450 exl. taxes euro overhere in Holland, without discs)
And like Dennis said : Not the easy way
Greetings
Matthy
Métisse is offline   Reply With Quote
Old 02-11-2008   #5 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
the difference must ony be in the head size - I am using busa calipers held on with ZRX bolts.. i.e. the caliper bolt holes are the same.
Make sure you use floating rotors with the 6 pots
Mick...
Old 02-11-2008   #6 (permalink)
Métisse's Avatar
I know, have read your other postings good, I think My rotors are ZXR9 don´t know exact witch year but 310 mm.
Old 02-11-2008   #7 (permalink)
t-bird brakes
thank you for the prompt and accurate reply. it seems that i will stick with the stock t-bird braking system for now. as for the 'busa brakes, i will post more when they arrive and see how that installation goes.
as always, thanks for the prompt and accurate information. excellent group of fellow riders.
S3 brakes Shreder Speed Triple Forum 7 05-20-2006 04:25 AM
Brakes dudley Trophy 7 02-27-2006 01:08 PM
better brakes cafestyle Club Cafe 30 07-15-2005 08:36 AM
brakes Celt Speed Triple Forum 16 07-11-2005 06:45 PM
Brakes IIMikeForce The Rocket Science Forum 5 07-09-2005 08:52 AM
