BikeBandit
Old 02-06-2008   #1 (permalink)
Favorite Bike: '08 Sprint ST
OUsooner's Avatar
Other Motorcycle: '99 T-Bird Sport
Extra Motorcycle: 2 Kids
Steering dampeners
What options do I have for a steering dampeners for my '99 TBS?
"No one makes me bleed my own blood"
OUsooner is offline   Reply With Quote
Old 02-07-2008   #2 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Sprint & Toby
Hi,
I know of two companies that have offered T300 steering damper kits, and I think they were born out of the Speed Triple Cup. You may like to take a look at the following old post: http://www.triumphrat.net/t3-sport-t...ed-triple.html
Although produced for the Speed Triple, I suspect the kit will work on all the Thunderbird models, etc....
I guess you are interested in this because you like the look, or because your TBS is highly modified? The standard Thunderbirds models are very stable machines normally.
Hope this helps?
Geoff
GeoffE is offline   Reply With Quote
Old 02-07-2008   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
It certainly isn't necessary on a stock TBS unless you have steepened the rake and do a lot of track days or ride on very rough roads. I have a Sprint damper and it works well. I'm not sure of the mounts are still available though. I can confirm that the Sprint damper was for the speed triple cup kit (that's where mine came from).
Mick...
Old 02-26-2008   #4 (permalink)
Exclamation .....just in case........
Hi,
A warning just in case anybody has a Steering Damper Kit to fit. One supplier appears to have provided bolts that are too long for the cylinder head mount. If you have one to fit, it will be worth double-checking the bolt lengths - see this post on the T3 Sport / Touring Forum: http://www.triumphrat.net/t3-sport-t...mged-cams.html
Regards,
Geoff
Steering way: Degrees of steering lock ChuckofTahoe Sprint Forum 9 09-02-2007 09:35 PM
Steering Damper. Xavi Gear & Gadgets 2 05-25-2007 01:19 AM
Steering Damper? Berkgeorge Twins Talk 10 09-21-2006 05:50 PM
steering damper? nissn1 Speed Triple Forum 0 01-02-2006 10:51 AM
Steering with the footpegs BigPappa Triumph SuperSports 13 12-25-2005 01:02 AM
