TOR's - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 02-03-2008, 12:49 PM   #1 (permalink)
Favourite Bike: 95 TBIRD
patrol21's Avatar
TOR's
Quick question-I pulled my stock peashooters and replaced. Noticed that the only baffeling is inside the enlarged area in the silencer. Essentailly, these are a straight pipes. From the other threads I may be wrong, but from the threads prior, people seemed to mention that you drill until you can see the light from the far side. Did my bike come with TOR's?? (I did not think the TOR's had the same look as the stock pipes). I might have my head up my back side on this question, but does the stock pipes have baffles that would restrict seeing all the way thru the pipe?
The worst day riding beats the best day at work....no exceptions.
patrol21 is offline   Reply With Quote
Old 02-03-2008, 01:00 PM   #2 (permalink)
jimmyj900's Avatar
If there's a stamped Triumph label that says 'Offroad Use Only' then you've got the TORS.
If you can see thru the mufflers and don't have a stamped Triumph label, then they're aftermarket.
If they've got the stamped label and you can see through then somebody's already drilled them.
Jim
Old 02-03-2008, 03:40 PM   #3 (permalink)
patrol21's Avatar
HI Jimmy,
Just checked em.....they're TOR's.
TOR's netsurfr Twins Technical Talk 16 09-12-2006 10:15 AM
TOR's with factory tune for the TOR's OKCTriple Speed Triple Forum 8 07-21-2006 02:35 PM
TOR's mjsharpe Club Cafe' 3 02-11-2006 09:51 PM
TOR's stevent Club Cafe' 6 09-17-2005 12:17 PM
Thruxton TOR's = Bonneville TOR's? Yes or No? Skeptic Club Cafe' 5 06-20-2005 11:57 AM
