Started today, but...
Well I cranked on her today, cranked and cranked, 10 seconds then left sit. 10 seconds left sit. I kept this up until the battery started to get fazed a bit and crank slower. I pulled #1 wire and dropped a plug on it and held it against the valve cover bolt, the spark seems a little dim to me. the I noticed it seemed as though it wasn't sparking consistantly, but in a different pattern. I probably didn't have it grounded well enough.
I pulled the battery after I ran it down a bit, took it to the battery shop and they tested it at 200+ CCA... I was rather suprised, they guy told me those batteries will regenerate a charge after being run on a bit.
Well I got home several hours later, popped it back in and cranked it a few times, don't you know the SOB started an ran!!! Go figure. It has been warmer out that has something to do with it but. ***?? I'm beginning to think I've got a flooding issue and or coils going bad. It does not run as well as it used to which lends me to think a coil is not firing properly all of the time. Funny but I did notice that the right pipe (primarily #1 cylinder did not push out as much watervapor like the right on... Strange indeed.
So how much choke do you guys with pods (and boxes too) use? 1/4, 1/2, full choke? I've always used just enough in the summer and mostly full on in the winter. I always cut the choke back quickly to prevent fouling and allow a good warm up prior to riding.
Btw, the bike is on a tender frequently and known of these mods have changed prior preformance, it always started well. a little coldblooded but NEVER like this.
Battery guy thinks my starter might be taking a dive and drawing too much juice thus cutting power from the ignition. sounds possible but... What do ya'll think?
I think your radar must be off...
