Old 01-26-2008   #1 (permalink)
Other Motorcycle: 1985 Shadow 1100
No Spark
I'm not getting any spark at the plugs. It's a 96 adventurer. The motor turns over. I don't see any loose wires but there is a white plug with a bunch of wires not connected to anything by the battery. I don't have a clue about the newer electronics, on bikes or cars. HELP!!!!
Caltrucker is offline   Reply With Quote
Old 01-26-2008   #2 (permalink)
These bikes use a wire harness that probably fits a few other makes/mfgs.
I'm pretty sure the white box with no connector your talking about is on my bike as well.
A friend of mine with a Bonneville America says he has 3 such connectors that go to nothing. So no worries there.
As for having no spark, some more details are needed. Did you just buy the bike?
Was it running normally before?
Does everything else work ie: Horn,Headlight,turn signals?
Stay calm, be methodical and post what you find and we'll get you through this.
No quarter asked, none given
Gdsila is online now   Reply With Quote
Old 01-26-2008   #3 (permalink)
tridentt150v's Avatar
Also need to know if you pulled a plug and visually checked the spark as you wound the motor over?
tridentt150v,
Great Southern Land.
tridentt150v is offline   Reply With Quote
Old 01-26-2008   #4 (permalink)
Favorite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast ;-)
i believe he's refering to the connector for the factory optional alarm .
first thing i'd do is put it in neutral , kickstand up and clutch in then try and report back .
hth
Woody1911a1 is offline   Reply With Quote
Old 01-26-2008   #5 (permalink)
I got it!!! I pulled in the clutch and it fired up. Thanks for the help. I'm going to wire around the clutch and kickstand switches.
Old 01-26-2008   #6 (permalink)
if you pulled in the clutch and it worked , it's probably the kickstand switch . they both serve an important purpose . get it fixed , don't leave it jumped .
annnnd you should always pull in the clutch when starting .
no spark Izzo Twins Technical Talk 8 05-31-2007 07:16 PM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 11 04-03-2007 04:14 PM
No spark hashman Club Cafe 3 06-06-2006 10:31 PM
no spark Redgoat Classic, Vintage & Veteran 17 08-26-2005 06:37 AM
No-spark Trudie Classic, Vintage & Veteran 12 05-17-2005 06:48 PM
