Old 01-22-2008   #1 (permalink)
Mounting the Summer Screen - Help
Just bought a Triumph Summer screen for my bike. I think it has all the parts but came with no instructions. Might anyone have saved the instructions that came with their summer screen and be able to post them here or scan them?
thanks in advance
Ride On!
meinschaft is offline   Reply With Quote
Old 01-22-2008   #2 (permalink)
Favorite Bike: 03 Stone Touring
TexasTri's Avatar
Other Motorcycle: 00 Legend
Extra Motorcycle: 72 DT250
I got mine used so no manual, sorry. If no one is able to dig one up I'd be happy to send you a few pic's of the mounting points. Just PM me where you want them sent to.
Russ,
TexasTri is offline   Reply With Quote
Old 01-22-2008   #3 (permalink)
Favorite Bike: 01 Legend
I guessed!
I did not get instructions with mine since it came used from e-bay. The large clamps go around the forks and the two little brackets attach through one of the lower pinch bolts on the fork tubes. Loosely attach all before aligning and then tighten. Good luck.
Most famous last words: "Hey ya'll watch this"!
jenglandtoyman is offline   Reply With Quote
Old 01-22-2008   #4 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Thumbs up
Hi,
I have the 'Windscreen fitting instructions' still (from 1995 - I believe the accessory is still the same?). Hopefully you can see the scans attached (and yes, I need a new scanner!).
The instructions came with the Summer Screen, but interestingly the drawings actually show the taller Winter Screen (which I also happen to have), as both use exactly the same fitting kit.
I should also add that although basically the same, the Thunderbird and Thunderbird Sport screens do differ, in that the Indicator cut-outs are at a different height.
Hope this helps?
Geoff
GeoffE is offline   Reply With Quote
Old 01-22-2008   #5 (permalink)
Thanks to all you guys - you are the greatest. I think the scans of the installation directions should do it. Thanks a MILLION!!!!!
Ride On!
America fly screen mount/summer screen combo mount? STL Triumph Twins Technical Talk 0 08-27-2007 09:23 PM
summer screen wildchild Twins Technical Talk 8 05-11-2007 09:50 AM
Triumph summer Windscreen mounting and photos Motoleo Twins Technical Talk 4 01-05-2007 07:37 AM
roadster screen on summer screen mounts? DaleE Hinckley Classic Triples 10 02-13-2006 09:10 AM
summer screen Hinckley Classic Triples 2 12-10-2004 04:43 PM
