BikeBanditMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 01-21-2008   #1 (permalink)
thunderbird modifications
I recently purchased a 1996 thunderbird. Cool bike. I want to make some modifications and am looking for advice.
I want to lower the bike. What is the best way to go about this. Is there a recommended shock?
I want to change the exhaust to something very short and stubby. Any recommendations?
I would like to change the seat to a solo seat. It appears there would need to be some modifications to hide the area on top of the back fender. Any ideas?
robbiealex is offline   Reply With Quote
Old 01-22-2008   #2 (permalink)
Favorite Bike: 00' Legend TT
Eyun_G's Avatar
A cowl style seat like the TBS would cover that area on the back fender.
Don't quote me on lowering, but you could probably either go with a shorter rear shock, or swap out the lower suspension link with a shorter one (Legend may be shorter). As for the front you can slide the forks up through the trees a bit to drop it without really hurting the handling.
Cooler than the other side of the pillow.....
Eyun_G is offline   Reply With Quote
Old 01-22-2008   #3 (permalink)
Favorite Bike: Thunderbird sport
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
Are you lowering for looks or for short legs? I would not lower it if your a corner nut like me.
I dropped the suspension height on several bikes due to the fact that I'm a little on the miget side. At 5'7" with short legs it's hard to find a bike that I like and that lets me get my feet flat on the ground.
I dropped the suspension on my Sv650 thinking I would like to be flat footed, not recommended it did effect the cornering of the bike, I dropped the forks in the triple tree and used a lowering link. I switched it back within two weeks of riding. Did the same another Ducati.
Fact is I've been ridinga bike too big for me my whole life, whether it was a Schwinn or a Ducati. I finally realized I will never grow into them!
If your not a cornering person and just cruise about then you should be fine.
I think your radar must be off...
oil-spitn-rat is offline   Reply With Quote
Old 01-22-2008   #4 (permalink)
Thumbs up Lowering A T-Bird
I got this info from this site last summer. Lowes and Home Depot were out of the flat bar stock so I went to a local steel supplier and they cut the bars for me to length. Both bars cost me about $9 total.
"Legend drop links will do the trick. These dog bone looking things on the rear suspension from a legend will lower it 1" & 1/4
Or you can make your own, 1"X1/4" mild steel flat bar. Cut to 8.5"
STock links are 7" centre to centre.
To lower 1 inch holes are drilled 7&1/4" c to c
To lower 1 1/2" 7&3/8" c to c
To lower 2" 7&1/2 c to c
Drop the fork legs through the triple trees a maximum of 5/8"
By the way I forgot to mention the holes in the drop links are 15/32" diameter "
T-Mac
T-Mac is offline   Reply With Quote
Seat modifications stu Twins Technical Talk 7 01-21-2007 08:06 PM
75 Mile Modifications flatso Twins Technical Talk 11 11-19-2006 09:55 PM
exhaust modifications need help britironrider Twins Talk 5 04-06-2006 04:18 PM
Modifications &Warranty ???? MikeInFlorida The Rocket Science Forum 7 03-08-2006 12:46 PM
wheel modifications spicytiger Tiger Chat 7 05-04-2005 12:59 AM
