BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 01-20-2008   #1 (permalink)
Favorite Bike: 96 Adventurer
Question Handle bar change
I have a 96 Adventurer with original bars. Would like to go with a lower bar & change grips, possibly ISO grips. Any suggestions.
Corey
AKMCDM is offline   Reply With Quote
Old 01-20-2008   #2 (permalink)
Favorite Bike: '99 Triumph Legend "The Green Wonderbike"
BigAl8295's Avatar
Sorry, I don't have any suggestions about handlebars for you, but I'm sure you will get your answer because that seems to be a common mod.
I'm looking to go a little higher and back myself.
There real reason I replied is that I see you're from Johnstown. I come out for Thunder In The Valley every year. Maybe I'll see you, there aren't many of us out there.
If loud pipes save lives, I'm a hero!
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, and one bad ass Horn Cover!
http://www.triumphrat.net/memberalbu...r/5547/cat/500
BigAl8295 is offline   Reply With Quote
Old 01-20-2008   #3 (permalink)
Be adviced that the control housings on left/right sides have a small plastic tab corresponding to a hole in the original bars. You either want to drill a similar hole in the new bars, or grind the tabs off. Grinding is easier, but you have to use a layer of electrical tape/duct tape on the new bars to secure the housings from moving.
Oh, and the original bar end weights won't fit the new bars unless you weld in a similar nut or mock up something from another set of bar end weights.
The future's so bright, I gotta wear shades
Tumbleweed is offline   Reply With Quote
Old 01-20-2008   #4 (permalink)
Favorite Bike: 2000 Thunderbird
Other Motorcycle: Wishing for MI3 Scrambler
The previous owner of my 2000 Bird put TBS bars on it and I think it looks and rides great. Granted I only ride around town during the week and not over 60 miles at a time on the weekends.
Kittlemeier is offline   Reply With Quote
Old 01-21-2008   #5 (permalink)
Favorite Bike: '99 TBird
NoDice's Avatar
I used NewBonneville.com's SuperBars designed for the scrambler (search "superbars"). They worked out very well... as mentioned, you'll want to drill two holes in the new bar to re-attach your throttle and choke controls.
As long as it's a 7/8" bar with enough room to fit everything back on, you should be all set. Good luck!
-Chris
NoDice is offline   Reply With Quote
Old 01-21-2008   #6 (permalink)
KD5QOQ's Avatar
I put MX bars on my Adventurer. Look about half way down the page. (the big pic)
http://www.triumphrat.net/hinckley-c...assics-11.html
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
KD5QOQ is offline   Reply With Quote
Old 01-21-2008   #7 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
I swapped my '96 Adventurer's stock bars out for some standard Thunderbird bars last year. The standard TB bars are much more comfortable, but, in some opinions, detract slightly from the "Cruiser Look" of the bike.
I find that the lower bars have much less flex and inspire more confidence in the handling of the bike.
I was considering going with some adapters and Gold colored Pro-Tapers at first. A quality set of aluminum MX bars would be a good choice as well, IMO. I'd skip the Bark Busters, though.
gregp is offline   Reply With Quote
Old 01-21-2008   #8 (permalink)
KD5QOQ's Avatar
"I'd skip the Bark Busters, though."
You just gave me an idea!
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
Old 01-21-2008   #9 (permalink)
Oh No! LOL! With the new interest in "Adventure" style bikes, and my deep seated interest in dirt bikes, I was starting to think about turning my Adventurer into more of an Adventure style machine. I already have the longer travel ZX shock, so a set of longer travel, leading axle forks might get me a bit more off road capability. I am only half-joking here.
Check this clip out:
http://www.vitalmx.com/videos/featur...rt,389/GuyB,64
Old 01-22-2008   #10 (permalink)
Favorite Bike: Thunderbird sport
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
I myself went with a little higher bars, they where streetfighter bars by Renthal I believe. Not quite bullhorns but it did take a little to get used to. I'm in Hagerstown we should ge together for a ride.
I think your radar must be off...
oil-spitn-rat is offline   Reply With Quote
Handle bar coversions tabbycat Modifications & Workshop Talk 0 05-10-2007 06:05 AM
Handle Bar options Devious2XS Speed Triple Forum 32 10-04-2006 09:14 PM
handle bar extensions Tooth Trophy 14 06-12-2006 08:14 AM
handle bar vibes mag10 Twins Talk 2 04-07-2006 08:20 AM
handle bar flipped over jmpowie13 Speed Triple Forum 0 05-23-2004 07:42 AM
