Motorcycle.com
Old 01-16-2008   #1 (permalink)
Favorite Bike: Thunderbird sport
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
Timing retarded...
Hey I've noticed almost all of these new bike have the timing retarded a bit or a lack of advance. Most likely just as modern car manufactures have done to help with emissions. I know there is a company that sold an advancer kit for our 900's.
Has anyone tired one?
Would this bring down my torque a bit lower in rpm range?
Would I need to retune the bike or just drop it in?
Who sells these and how much?
would this cause any negative effects on the starting or overall performance of the bike?
Thanks a million Ken
I think your radar must be off...
oil-spitn-rat is offline   Reply With Quote
Old 01-16-2008   #2 (permalink)
Favorite Bike: 98 Thunderbird
Factory Pro make one. I have no idea if it is worth the money, but I do believe that if you fit one you have to use higher octane fuel to avoid detonation. AFAIK it's a drop in mod, no other mods needed.
Old 01-18-2008   #3 (permalink)
I bought one. Most everything is covered in this thread:
http://www.triumphrat.net/hinckley-c...nition+advance
BadMouth is offline   Reply With Quote
Old 01-22-2008   #4 (permalink)
Thanks
Bad Mouth
Thanks for the post, I'm going to go ahead with this mod in the spring. I hope they still make the little suckers!
Old 05-07-2008   #5 (permalink)
Fyi
No longer in stock at the above mentioned company and likely not to ever be restocked...
Old 05-08-2008   #6 (permalink)
Favorite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: 1982 KZ 750
I believe that somebody else here has filed the holes out a bit to allow rotating the trigger a few degrees. Same result.
gregp is offline   Reply With Quote
Old 05-08-2008   #7 (permalink)
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
I would be interested to hear what they did.
The OEM part and a bit of filing is about half the price of the FP part.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 05-08-2008   #8 (permalink)
It was something like this: (posted here http://www.triumphrat.net/hinckley-c...tml#post943459
Model: 1998 Tbird
Carbs: Mikunis
Airbox: Stock K&N Filter, air inlet 'foam silencer' removed
Intake rubber 'restrictor' reduced by est. 8-10% (area)
Exhaust: Thunderbike 3 - 1
Cams: Stock
Ignitor: Stock
*****Ignition Pick Up: Est. 2 deg advance filed from mount holes (rotor circumference ~ .65mm / degree*****
Old 05-11-2008   #9 (permalink)
Favorite Bike: Tbird
IrlMike's Avatar
Yep, it was me that filed the igniter pick up mount holes to give est 2deg advance. No problems with detonation on regular fuel. I believe engine makers are likely to build in tolerance when setting the firing point & I'm just taking some back. You can always slide the pick up back round a bit if you're not happy with results. My 'butt dyno' thinks it's an improvement
____________________________
--__Y
...0-0.......^...........^^u.....^...... Ireland, home of street motocross....
Jazz isn't dead, it just smells funny
IrlMike is offline   Reply With Quote
Old 05-11-2008   #10 (permalink)
Considered that
File or modify the existing that is. I think I found one from Parts Unlimited. We'll see if it comes in, I had my dealer order one as I couldn't find one stocked at most of the online bike shops. I know there will be a bit better windup time which is what I'm looking for. Now to fint the new Epco pipes on the way!!
maybe im retarded but... ralix13 Twins Technical Talk 3 10-22-2007 11:29 AM
valve timing kubbie Triumph SuperSports 3 02-07-2007 03:02 PM
timing musicman59 Classic, Vintage & Veteran 0 09-11-2005 07:08 PM
Timing and Valves Trudie Classic, Vintage & Veteran 10 08-30-2005 04:36 PM
need cam timing help .please Modifications & Workshop Talk 10 02-29-2004 12:58 PM
