Old 11-18-2007   #1 (permalink)
Newbie
Favorite Bike: 96 Thunderbird
Other Motorcycle: 99 Sprint ST
Thunderbird won't stop cutting out
Hi all
I have a 96 Thunderbird that keeps exhibiting classic pickup coil problems.
After running for while, it will intermittently start losing power and then cut out alltogether. Leave it 10 minutes and it starts again fine.
I have replaced the pickup coil, replaced the Gil coils with Nology ones, cleaned the carbs and the fuel cap is not causing a fuel vacuum. But it is still doing it. It's not so bad at the moment, but it's pretty cold and it was worse when the weather was hotter.
I went to check the tip-over valve but found that it was missing, along with the breather hose. So I'll need to fit a new one, but I don't think that is the problem.
The only thing I can think of is changing the ignitor box. What does anyone think?
Oh, the horn doesn't work (it does when attached directly to the battery but not using the button). Probably just a dirty terminal or something similar.
Any ideas for what to check next as if it's not the ignitor box I'd rather not waste the money.
Sprint2red is offline   Reply With Quote
Old 11-18-2007   #2 (permalink)
jimmyj900's Avatar
Is this happening at an idle in the garage or on the road?
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Old 11-18-2007   #3 (permalink)
Newbie
Sorry, should have said.
The bike idles fine, seems to happen after riding for while and generally seems to show around 4,000-5,000 rpm.
Although it did once 0.5 miles from home on a hot day.
Old 11-18-2007   #4 (permalink)
Tre900's Avatar
Try this..
While your at home in garage..fire it up..let it idle for a little while, then giggle the key in the ignition a little bit (don't force it in any direction).
See if at any point the movement of the key kills the bike. If so it could be your ignition has a lose connection.
Had classic coil symptoms but resulted in ignition and was hard to troubleshoot cause it was so speratic.
Gooooooooooooooooooooooooooooood luck
Tre900 is offline   Reply With Quote
Old 11-18-2007   #5 (permalink)
jimmyj900's Avatar
Does this problem occur with the fuel tap in the ON position (arrow down), the RES position (arrow up) or both?
How much fuel is in the tank?
Jim
Old 11-20-2007   #6 (permalink)
jimmyj900's Avatar
Rather than let this thread drift off into limbo...
I suspect that there's cr*ap in the fuel tank that's either restricting flow through the tap or has mostly plugged the duckbill filter in the carburetor fuel connection 'T'.
The tank may have rust (from the fuel tank itself or the local gas station), dirt (another gas station freebie), wax buildup in the bottom of the tank or some other nasty floating around that's blocking the fuel tap filter.
If there's dirt or rust in the tank, then it's found it's way to the duckbill and that's probably reduced flow to the point that there isn't sufficient flow into the float bowls and the bike starves out. It would then take a few minutes for the fuel level to come back to normal so the bike will start.
Jim
Old 11-21-2007   #7 (permalink)
Newbie
Been away working for a couple of days.
I tried the ignition key this evening and everything was fine, so it's off with the fuel tank and out with the tap this weekend.
Thanks for the advice, and everything's crossed that it'll get fixed this weekend.
Cheers
Dave
Why did Triumph stop making the Thunderbird and Adventurer? gonzo'st100 Twins Talk 19 02-02-2008 03:29 PM
Engine stall-out/Shut-off at stop light/stop sign??? jrelloway Daytona Deliberations 7 02-01-2008 02:16 PM
cutting out thunderbird scutty900 Hinckley Classic Triples 32 06-14-2007 12:17 PM
Engine cutting off at stop lights Stoudty Hinckley Classic Triples 4 06-23-2006 12:56 AM
will a thunderbird tank fit a thunderbird sport? aeycue Hinckley Classic Triples 1 06-24-2005 03:54 PM
