Old 01-13-2005   #1 (permalink)
I have been losing oil recently and initially thought I had overfilled the bike, after it got to the point where I was going to go below the sightglass I took action and removed the front sprocket / clutch cover.
here was the front sprocket
the other way round ( to confirm the tooth twist )
I pulled both oil seals ( shifter and clutch rod ) and they were starting to go bad ( probably both original)
I bent back the tabs on the washer and ending up using a 2 foot length of 2" exhaust pipe as a breaker bar while I balanced on my right leg with all my weight on the brake pedal.
I flushed all of the clutch hyd. fluid mainly due to not using zip ties on the piston, doh. then one of the screw heads in the hydraulic reservoir decided to strip, luckily I had a spare from when one on the front brake side did the same thing.
I had to drill the head off which was a very precarious situation.
finally got that sorted
After replacing everything with nought but a new gasket and some elbow grease and the smallest dabs of rtv it was buttoned back up ( BTW cranking up the front sprocket by myself was not easy I recommend finding a friend to help) and I refilled the oil .
No leaks since and my new chain is having a much smoother life now
I worry about the sightglass though, sometime it looks like its just some residual oil in the bottom of the window rather than filled evenly ( on the flat on centrestand.)
Im tempted to add some more oil but dont want to tempt fate too much.
[ This message was edited by: durkster on 2005-01-13 10:57 ]
durkster is offline   Reply With Quote
Old 01-13-2005   #2 (permalink)
Favorite Bike: 03 Stone Touring
TexasTri's Avatar
Other Motorcycle: 00 Legend
Extra Motorcycle: 72 DT250
While you had it apart did you also replace the rear sprocket and chain? I believe it is recommended to do them all at the same time. I'll assume the seal was what caused the oil leak. How many miles did you have on this sprocket, or chain sprocket combination?
Russ,
TexasTri is offline   Reply With Quote
Old 01-13-2005   #3 (permalink)
The chain is a two - three weeks old triumph supplied replacement DiD oring that has been cleaned twice and oiled daily.
I didn't have all the seals and gasket for the front and my chain was 100% shagged with no more on the tensioners so it had to be done.
Front and Rear sprocket will get done together when I put on a DiD X-ring chain I have , the rear sprocket is still in remarkably good shape plus I got some good deals on the chains.
The bike is up to 15600 so say 15,000 miles on the original regina chain and front sprocket, not too bad considering the actual age of the chain itself.
[ This message was edited by: durkster on 2005-01-13 11:11 ]
Oil leak behind front sprocket Sonoma Tiger Workshop 2 08-06-2007 03:36 PM
Any one have a drive sprocket oil leak? amanger Sprint Forum 7 04-06-2007 06:02 AM
Oil around the front sprocket cover bruin Twins Technical Talk 22 11-22-2006 06:35 PM
Leak proof fork seals johnquinnell Classic, Vintage & Veteran 2 03-29-2006 11:48 PM
Oil leak - front cam gasket Springbok Club Cafe 2 09-20-2005 07:09 AM
