BikeBandit
Old 11-02-2007   #1 (permalink)
TBS Gauges
Hey all,
Anyone know of any gauge sets from other Triumphs that will more or less "plug and play" as a replacement for TBS gauges?
Any experience with even a mod requiring some basic electrical knowledge would be great.
Cheers!
blackfly911 is offline   Reply With Quote
Old 11-02-2007   #2 (permalink)
superfour's Avatar
Do you mean other than the Thunderbird or the Adventurer? In theory the early Trident/Trophy/Daytona type would fit also,I think.
Currently riding a black Tiger 955i
Stuart
superfour is offline   Reply With Quote
Old 11-02-2007   #3 (permalink)
Cafe Racin' Moderator
Favorite Bike: 1996 Triumph Thunderbird
cafetbird's Avatar
Other Motorcycle: 2002 Triumph Sprint ST
Extra Motorcycle: 1973 Triumph TR7RV
Yep - all the T309 bikes will work. Lots of folks liked the 1st gen Speed Triple gages as a replacement - the faces were white.
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
Old 11-03-2007   #4 (permalink)
Favorite Bike: Shovelhead.
Emanthehorse's Avatar
Other Motorcycle: 98 TBS
Extra Motorcycle: 1971 Triumph TR6R Chop.
Apparently there are some differences, I picked up a replacement speedo from a Tbird for my TBS and had to modify the plastic 'cup' to get it to work. If you can get one with the cup included you should be good.
Emanthehorse is offline   Reply With Quote
Old 11-04-2007   #5 (permalink)
Ideally you can make any t3 and some t5 instruments work. As mentioned above some cup modifications may be needed. 95-97 had slightly longer metal gauge cups. Post 97 had shorter plastic cups. Which affected the stud length of the gauges.The later Daytona's and S3's had even shorter retaining studs.
Studs can be changed out from gauge to gauge using a little heat and some pliers. If you switching from T5 S3 gauges you'll need to make new pilot holes where the studs are to go. If you don't have the proper length stud 5mm allen bolts are close to the original stud base size a little epoxy and your back in business.
If you changing out a tach there are couple different wiring connections to deal with.
screw and eyelets
bullet connector
plastic hardshell connector to the back of the gauge
Just make a jumper to match the vehicle harness
zs-cafe is offline   Reply With Quote
Old 11-05-2007   #6 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Or get the correct harness with the gauges... e.g. the early speed trip gauge harness plugs striaght into the TBird main harness without modification.
Mick...
Gauges Luxamor Street Triple Forum 8 12-05-2007 02:10 PM
For those that have had their gauges apart... TroyH Club Cafe 5 02-02-2007 09:15 AM
Gauges multi Lee The Rocket Science Forum 3 09-27-2006 08:13 PM
05 ST Gauges Mach1 Sprint Forum 7 09-29-2005 05:31 PM
Gauges coastie Triumph SuperSports 2 06-08-2004 12:53 AM
