AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 10-26-2007   #1 (permalink)
Administrator
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Carb Balance Question
I did the air-box mods and rejetting to my TBS back in June and at the time I checked the balance of the carbs and it was close enough that I was not going to try to get it any better.
Not long after doing all this, I stacked my other bike and the TBS has sat for close to 4 months while I have healed.
The TBS is now running like a pig, which I am assuming is from gummed up carbs.
I have some carb cleaner in the tank at the moment but have not done enough miles to make any appreciable difference yet.
So to my question,
If a jet in one carb is more blocked than in the others (which I think may be the case), would that show up on the carb balance tool?
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 10-26-2007   #2 (permalink)
Thats a curly one. Stick em on and see what happens. I dont think it should change unless its actually backfiring on that cylinder.(Carb backfire I mean)
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 10-26-2007   #3 (permalink)
Favorite Bike: 98 Thunderbird
The problem is most likely a gummed up pilot jet. Seeing as you are running on the pilots when balancing the carbs, it should show up clearly on the gauge.
Old 10-26-2007   #4 (permalink)
jimmyj900's Avatar
Originally Posted by Wombat View Post
...the TBS has sat for close to 4 months ... is now running like a pig, which I am assuming is from gummed up carbs.
So to my question,
A carb balance compares the vacuum at the engine side of the carbs after the throttle butterfly.
The butterfly opening at idle is very small but it's still much larger than the combination of pilot air and pilot fuel jets that supply emulsion via the transfer ports, so you're not going to see a blocked pilot fuel jet during carb balancing.
You might be able to see a blocked pilot air jet, but that's doubtful.
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Carb Balance jimmy bush Classic, Vintage & Veteran 4 02-22-2008 01:57 PM
Carb balance trick monkeyboy Twins Technical Talk 18 11-26-2007 09:48 AM
Carb.balance after AI yank? speedblastr Twins Technical Talk 7 05-30-2007 05:25 PM
sprint carb balance watty T3 Sport / Touring Forum 2 05-04-2004 06:30 PM
carb out of balance Trophy 12 04-09-2004 10:25 AM
