I use a *cheap* deep socket for sparkplugs (the cheap ones have the thinnest walls and drop into the plug cups easily) and a magnetic pickup tool to remove the socket and plug once loosened.
To install the new plug, I put a small dab of anti-sieze compound on the end of the thread, lower the plug into the cup with the magnet and drop in the socket. After tightening I use the magnet to remove the socket from the cup.
To keep from cross-threading the sparkplug, rotate it counter-clockwise and listen/feel for the "click" when it drops into the beginning of the thread. Then finger tighten until snug -- if everything is right and the threads are good it should run in smoothly.
Jim
