I thought I'd share my progress on my fender chop and get some feedback/ideas.
I started out with a legend fender, chopped it, then removed the ridge and the brake light mounting holes. I've wanted red signal lenses for a while and the only way to get them was to swap out turn signals. While I was at it, I installed a run/turn/brake module so the signals could double as brake lights.
It has turned out close to what I had envisioned, with the exception of the license plate lighting. The plan was to use license plate mounting bolts that have LED's built into them, so I wouldn't have to clutter things up with a light housing. The lights would work fine on a flat license plate, but I ran into problems using a curved one. Due to the curve, the light can only illuminate a small section. To illuminate the plate this way, it will take 5 or 6 bolts. That will clutter things up and cost me another $40.
I'm still exploring my options. (btw, the wide rear rim is at the powder coater and should be laced & installed within the next few weeks. The front rim is on backorder until mid-november)
So what are your thoughts?
Go ahead and use 6 giant license plate bolts? Add a sparto? Move the plate to the swingarm? Chop it farther?
