Old 10-12-2007   #1 (permalink)
losangeles_S4's Avatar
96-97 Adventurer Starter Problem
Ok. Buddy of mine with a 96-97 Adventurer road with me up to motoGP at Laguna Seca this year. On the way up his bike started making strange sounds at startup. Sorta a binding sound on and off. The bike would eventually start, but it was unpredictable. Because of the "bad sound" we went to pushstarting for the rest of the trip. My understanding is now the starter just spins and the binding sound is gone. Bike has been sitting for a month or so now I want to help him get back on the road.
I don't know this bike very well, but I noticed the weaker starter clutch mentioned in the Common Problems sticky.
Is this what we are looking at? Dealer told him this an expensive repair. They have not seen the bike. They mentioned a "bandex gear" or something to him on the phone. Engine has to come out of the frame or something?
It sounded to me like starter teeth and flywheel teeth grinding.
Best,
Erik Hillard
2002 Triumph Speed Triple
1976 BMW R90
losangeles_S4 is offline   Reply With Quote
Old 10-12-2007   #2 (permalink)
jimmyj900's Avatar
That sounds like the sprag clutch. A bad starter can make a grinding sound while cranking the engine if the bearings are shot, but if the starter is turning and won't crank the engine then either the starter is loose (check that), the teeth are stripped (improbable) or the sprag is broken.
The sprag is sort of like a Bendix drive in that it couples the starter to the engine, but it's a totally different animal and you can't just remove the starter to get at it. It requires removing the engine and a tear down to get to the Sprag and I don't think the new (larger) sprag will fit without some machining inside the engine case.
Sorry about the bad news on that.
Jim
jimmyj900 is online now   Reply With Quote
Old 10-12-2007   #3 (permalink)
Wow. That sounds nasty. Not a job for the faint at heart it sounds. Hmm..
Best,
Erik Hillard
1976 BMW R90
Starter problem. WoodsieIII Hinckley Classic Triples 16 12-29-2006 08:17 AM
Sensor behind the starter problem..... Quackster Speed Triple Forum 6 08-20-2006 10:52 AM
Sensor behind the starter problem..... Quackster Speed Triple Forum 0 08-19-2006 03:32 PM
starter problem? whoa Tiger Workshop 2 01-15-2006 02:27 PM
Starter Problem Blackhead Hinckley Classic Triples 2 11-03-2004 04:12 AM
