This is a bit of a tale, I've asked a few questions in past threads but have hit dead ends on all. So, I figured I'd ask here again and see what the consensus is.
I have a 98 TBS, great bike. Only "issue" I've had since I bought her has been weeping fork seals, which I had replaced. When the mechanic replaced them he stated he had to clean up some pits on the rt tube and thought as long as I kept a light coat of oil on the tube to prevent further pitting, they should be fine. Well, despite my best efforts, the leak has returned on my rt tube, so I looked at:
- Forks by Frank, he has listings for TB but not TBS, I can't seem to confirm if a TB will work on a TBS.
- local Triumph dealer, he says they can't get tubes alone, only as a complete fork assembly.... at about $800 each side
- hard re-chroming, I've only read about it on the net, but I wonder about the cost or it vs replacement!
- Motorcycle recyclers.... it's not easy to find a TBS at the best of times and like the vast majority of bikes, front end damage is usually the problem anyways: and
- full front end suspension swap, which I considered but I'd rather keep the bike as original as possible.
Can anyone help me out with some advice, how they overcame a similar issue, or what would be the best fix in this situation! I'd rather not cause any more damage or jeopardized safety by continuing to ride her in her present condition and I'm getting tired of telling the guys I can't go ride cause' the bird's got a broken wing, HELP!
I also received some advice to go the epoxy fix route, but would really like to get this issue sorted out "long term".
