Old 12-12-2004   #1 (permalink)
Can I install a stock Thunderbird exhaust setup on a Legend? If not what are some good sources for a decent set of peashooters. And will I need major carb adjustments? Riding for decades but still a mechanical idiot.
Thanks!
Mark
Old 12-12-2004   #2 (permalink)
Thanks!
Mark
Old 12-12-2004   #3 (permalink)
I've seen peashooters on a Legend. Shouldn't be a problem. In fact when I changed the sprocket on my Legend I had to remove the mufflers. It's just one bolt on the footpeg and one on the pipe. Slip off/slip on. Cant see why it would be any different with TBird mufflers.
P.S. I did not re-jet. I sorta like the (Minor)popping on de-cell
Good luck, ride safe ,Gdsila
No quarter asked, none given
Gdsila is offline   Reply With Quote
Old 12-12-2004   #4 (permalink)
Old 12-12-2004   #5 (permalink)
Favorite Bike: '99 Legend
I have peashooters on my 99 legend. The Triumph part number is 9730001. Although they are "not for rad use" they are not real loud unless accelerating. They fit, look and sound great. I have pics on my photo album.
safe riding
Mark
If it were easy, everybody would be doing it and we would all be out of a job!
legend is offline   Reply With Quote
Old 12-12-2004   #6 (permalink)
safe riding
Mark
Old 12-12-2004   #7 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Legend and thunderbird mufflers are interchangeable, no jetting changes are required.
Here's a tip though - do not try to remove the steel mounting brackets from the mufflers. Doing so can trash the mnuffler (the captive nut breaks loose very easily).. Simply undo the single bolt that holds them to the subframe and remove the muffler complete with its brackets. The brackets are cheap (about $10 each IIRC) and held on by M8 stainless bolts. buy a new set for the new mufflers, if your replacements don't already have them (which they wont if you buy new).
Mick...
Old 12-12-2004   #8 (permalink)
Mick...
Thunderbird seat on a Legend skeeter1949 Hinckley Classic Triples 9 08-07-2007 05:04 AM
The Legend of the Thunderbird? cafetbird Hinckley Classic Triples 3 11-05-2006 07:00 PM
Legend speedo on a Thunderbird carpelux Hinckley Classic Triples 13 09-23-2006 10:58 AM
Legend/Thunderbird GerryP Hinckley Classic Triples 9 11-14-2005 01:23 PM
The Legend of the Thunderbird cafetbird Hinckley Classic Triples 7 08-04-2005 11:41 AM
