» Log in
User Name Not a member yet?
Register Now!
  #21 (permalink)
Old 02-20-2008
IrlMike's Avatar
Favorite Bike: Tbird
Patrol21
I started out working the restricted rubbers a bit, keeping well clear of the indents each side - maybe 8-10% area reduction. Then I checked out a few more posts & compared the fiches for TB & TBS.
TBS cams, airbox, igniter etc. all the same. Just different exhaust....& Keihin carbs with their unrestricted rubbers & same jets, needles etc as the later TB that had Keihin....+14bhp TB to TBS ?...some smoke & mirrors going on here methinks
So figured I had to try those rubbers - they are from Mikuni carbed Tiger, I believe, part # T1240080
The results are excellent, midrange was good before tho' not as strong as low end & top end - now it's stonking torque right thru'
Interestingly, even tho' there was still a huge area difference between my 'worked' ones & the Tiger rubbers, no carb adjustments were needed.
I posted the full info. on the Proven Setups sticky.
It's quite possible the Dynojet parts don't make much difference & may not be worth the bucks. (My stock needles were worn tho') Very likely a 95 main jet, a notch or 2 richer on the needle, & 2 1/2 turn pilot screws will do the job....I would run that past the tech gurus here first tho'.
IMHO the .5 mm richer on the float heights is good for low revs high throttle pull.
Go for it !
  #22 (permalink)
Old 02-20-2008
IrlMike's Avatar
Just realised I was already on the Proven Setups sticky
Couple of further thoughts....
That TBS exhaust seems to play a key role here over the TB, cos the airboxes are identical. Maybe it's to do with 'scavenging' - kind of turbo charging on the cheap one cylinder exhaust 'pulse' from a cross connected header can help to 'pull' the charge thru' another cylinder on it's intake stroke. I suspect the Thunderbike 3 into 1 maybe doing just that.
However, it may be that airbox mods can make up for this when using stock headers & TOR mufflers. Tho', as that rear airbox plenum is a 'tuned' resonant (air) circuit, the characteristics at different revs / throttle will be slightly different again...
All I can say is that my TB pulls like train with a 19t front sprocket (11% higher gearing) & still does 50+ (Imp) mpg - result
Thanks to all the posters who gave me the info to do it !
  #23 (permalink)
Old 02-22-2008
patrol21's Avatar
Favorite Bike: 95 TBIRD
Hi Mike,
Thanks for the tips. I think I'll get with the Tiger rubbers. Cheers!
The worst day riding beats the best day at work....no exceptions.
  #24 (permalink)
Old 02-22-2008
cafetbird's Avatar
Cafe Racin' Moderator
Favorite Bike: 1996 Triumph Thunderbird
Other Motorcycle: 2002 Triumph Sprint ST
Extra Motorcycle: 1973 Triumph TR7RV
Model: 1996 Thunderbird
Carbs: Mikuni
Airbox: K&N in stock airbox w/ 4 1.5 " holes
Exhaust: Yoshimura 3-1 for 96 Speed Triple
Cams: 96 Speed Triple (Green)
Ignitor: 96 Daytona Super III (9700 red line)
Main Jets: 120
Needle: Dynojet, center notch
Float Height: Standard
Pilot Jets: 40
Air/Idle Screws: 2 3/8 turns out
Iridium Plugs
Factory Pro 4 degree ignition advancer
Bike pulls hard throughout the range, slight flattening in the 4-5 range. Pulls real hard on the top end. Dyno'ed at 90 hp right after Yohsi install.
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
Photo Album
  #25 (permalink)
Old 03-15-2008
patrol21's Avatar
OK, the weather just got warm enough to pull the bike out of the shop and see where my mods stood.....ouch, Im used to hard reving and I have to change my timing.....I am hitting 7500-8000 RPM a ton faster......these bike are stangeled stock. Anyhow, IRLMike/Jimmy, Greg, thanks for the tips..here is what I ended up with
Air-K/N replacement (drilled some airbox holes but ended up too lean) taped them all up. Opening up the airbox is opening up pandora's box. If I have one piece of advise...leave it be or go with PODS (Jimmy's advice)
Mains-after much swiching around, I settled on the higher DYNOJET mains (came with kit)
Pilots-stock 40
Needles-DYNOJET on 3rd notch-made a huge differnce with throttle response
Pipes-removed TOR's and went with EMGO's. Can you hear me now?
Float height-14.5
Have not put on a dyno yet but the butt dyno leaves me tingling and my shift timing has to be much quicker........... But officer, I'm just getting used to the mods.
  #26 (permalink)
Old 03-15-2008
patrol21's Avatar
just to add from above.....
Unresticted rubbers-Tigers from that year have them...bike bandit had em
one step hotter plug...(not sure if this was necessary)
  #27 (permalink)
Old 03-16-2008
IrlMike's Avatar
Patrol21
Cool
Brief mods to my set up so far:
Fitted Thunderbike 3-1 optional (& removable) 'DB Killer' baffle, cuts the noise down a bit especially at low revs, tho' still way louder than stock. Recommend
No jetting changes made, tho' only a brief trial as I've now changed over to stock Keihins. (Needle Jet/Slider wear gremlins )
All ok & good power but will probably go for a Factory Pro needle kit, as I feel there's a little more 'umph' to be had at low/mid revs which I think the Dynojet needles on Miks did well.
____________________________
--__Y
...0-0.......^...........^^u.....^...... Ireland, home of street motocross....
Jazz isn't dead, it just smells funny
  #28 (permalink)
Old 03-17-2008
patrol21's Avatar
Hi Mike,
The mods made a huge difference. I am not running my mains at the settings that I see listed on the forum....120's/130's....seems rich but I may go that route in time. Right now, I am estatic with the pull I am getting. I don't see a huge increase in top end but it gets there a ton quicker. I think going with the unrestricted rubbers made a huge difference..thanks for the part#'s off the old tigers. Anyhow, I have a good friend that I ride quite a bit with that has a Harley with about 4,000 invested in the motor to give it more umph.....we were nearly side by side thru the gears last year......I guess he'll be eating some Trumpet Dust this riding season..bon apetite..see ya!
  #29 (permalink)
Old 03-19-2008
tridentt150v's Avatar
Back to the Future
I did this:
http://www.triumphrat.net/hinckley-c...ighlight=t150v
Mains, 118
Pilots 40,
Thruxton needles.
I can get my airbox off in seconds, I can get my carbs off in under a minute.
Ridden it over 4,000km now and all over the rev range and in the rain and on +40'C days and had no problems. Definitely more power, and very smooth, plus it cut my 'back off pops' down heaps.
I'll get it dyno'd one day, but I was just happy to junk that cracked plastic wash basin they call an airbox for some steel!!!!
tridentt150v,
Great Southern Land.
  #30 (permalink)
Old 03-21-2008
banjo dave's Avatar
Favorite Bike: A running one
Other Motorcycle: 1981 Suzuki Jr50
I tried using part #T1240080 @ my local Triumph dealer and they couldn't pull anything up with it. Is that number specific for an outside company and not an oem #? What year Tiger for the Mikuni unrestricted rubber inlets? I want them, I need them, I've got to have them! Optimum performance please!
1996 Thunderbird
Jetting Whitehurst Club Cafe 4 12-24-2007 04:07 AM
D&D Jetting technogrunt Twins Technical Talk 6 03-01-2007 07:57 AM
JETTING HELP?!?!? Brooksie Twins Technical Talk 4 01-05-2007 01:07 PM
How about a member list of tuning setups? dazco Triumph Twins HangOut 9 07-28-2005 06:51 PM
possible setups Modifications & Workshop Talk 11 09-01-2003 02:42 PM
