» Log in
User Name Not a member yet?
Register Now!
  #11 (permalink)
Old 11-05-2007
funhunter63's Avatar
Favorite Bike: 99 Thunderbird
Other Motorcycle: 98 Trophy
Extra Motorcycle: 83 Goldwing
The latest set-up
Model: 1999 Thunderbird (standard)
Carbs: Keihin CVK
Airbox: K&N in standard filter box w/ 5 x 1.5" holes
Pipes: Stock
Muffler: TORs
Cams: Stock
Ignitor: Stock
Main Jets: #120 Keihin
Needle: Thruxton needles
Float Height: 17.5mm
Pilot Jets: #40
Mixture Screws: ~ 3.0 turns
Plugs: DPR7EA-9
Butt Dyno Results:
Small throttle operation good. Smooth to 7000 rpm, no bucking or audible misfire.
WOT test:
Better WOT operation with Thuxton needles at low and mid RPM. Thanks Jimmy!
  #12 (permalink)
Old 11-17-2007
Model 97 Thunderbird
1 Mikuni carbs taken off and replaced with Keihin CVK carbs off a 2001 model
2 Airbox in the bin - fitted pod filters S&B maxi-flow 125-RC-T conical (2.25x3.5x2x4) onto the Keihin CVK's. These are totally "free flow" and would give the same air flow as no filters at all. Air inlet (bellmouth) size is 57mm (CVK's only, Mikuni are different size)
3 Restrictive intake rubbers (with dimple) replaced with unrestricted (smooth) intake rubbers. The unrestricted rubbers should be standard with Keihin CVK carbs
4 Standard spark plugs changed for NGK Irirdium DPR8EIX-9
5 Main #98 jets replaced with #120 jets - This works perfectly the plugs are just the right colour (I live at sea level). Jimmy reckons it might be worth trying #125's but the risk is it might run rich at 5000 rpm to 7000 rpm
6 Copper washer under each carb needle - didnt seem to make any noticable difference but did it anyway. The needles on CVK carbs are not adjustable.
7 Mixture screw taken another full turn out
Everything else is stock ! Fuel is standard 95 RON.
Picture at:
http://www.triumphrat.net/hinckley-c...120-mains.html
Im so pleased with the result I havnt bothered fiddling around anymore, The bike really smooths out at 4000 rpm to 5000 rpm and the iduction roar is fantastic bearing in mind the exhaust is standard. The economy as well as the power has noticably improved, I get about 20 more miles per tank. Recommended !
  #13 (permalink)
Old 01-07-2008
bkline's Avatar
Originally Posted by bkline View Post
Model: 1996 Adventurer
Carbs: Mikuni
Airbox: K&N in stock airbox w/ 4 1.5" holes in the back
Exhaust: Thunderbike 3-into-1
Cams: Stock
Ignitor: Stock
Ignition Rotor: Factory Pro Ignition Rotor Advancer (+4 degrees)
Main Jets: 145
Needle: Dynojet, 2nd notch from the top
Pilot Jets: 40
Air/Idle Screws: 2.5 turns out
Notes: Haven't gotten around to the dyno yet, but pretty steady torque according to the butt dyno. It pulls so well now that I installed a 19T front sprocket. I was willing to trade a little torque for the lower revs on the highway. It's like adding a 6th gear.
This Winter, chucked the airbox altogether and went with K&N pods:
Carbs: Mikuni
Airbox: K&N pods
Cams: Stock
Ignitor: Stock
19T front sprocket
Main Jets: 155
Needle: Dynojet, 3rd notch from the top
Float Height: stock
Pilot Jets: 40
Air/Idle Screws: 2 3/8 turns out
1996 Cafe Adventurer Project
http://www.triumphrat.net/memberalbu.../14456/cat/500
  #14 (permalink)
Old 01-28-2008
Favorite Bike: Thunderbird sport
Other Motorcycle: Ducati- PS 1000 LE
Extra Motorcycle: speed trip
Dyno results
I've posted my dyno results under my "member album" as I've not been able to shrink them down to 800x0 and post them up. whp 73 torque 52ftlbs
Mods are pod filters (K&N) and BC preditor pipes. tell me what you think.
I think your radar must be off...
  #15 (permalink)
Old 01-28-2008
denny's Avatar
Favorite Bike: '98 Thunderbird Sport - Buford
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
What about your jetting, etc. I know you had to change something to get it sorted with PODS on there.
Cheers,Denny
  #16 (permalink)
Old 01-28-2008
final jetting mentioned in second pic, Shimmed needle (should be .030 as rewritten on a second sheet) .055/M J152.5.
I'm assuming the J = jet and size is 152.5??? Keep in mind I did NOT perform this rejetting myself.
  #17 (permalink)
Old 02-03-2008
Newbie
Favorite Bike: '99 Adventurer Cafe'd
Other Motorcycle: '73 Honda CB350
Extra Motorcycle: '85 Honda VT500
Proven Setups
Model: 1999 Adventurer
Carbs: CVK, no mods
Airbox: None- 3 K&N Pod/Filters
Exhaust: Stock, w/ baffles removed
Cams: Wilcox Engines.
Ignitor: Stock
Ignition Rotor: Stock
Coils & Spark Plug Wires: Nology
Main Jets: 120, FP
Needle: Stock, no change
Pilot Jets: 40, FP
Seems to work....
  #18 (permalink)
Old 02-13-2008
IrlMike's Avatar
Favorite Bike: Tbird
Model: 1998 Tbird
Carbs: Mikunis
Airbox: Stock K&N Filter, air inlet 'foam silencer' removed
Intake rubber 'restrictor' reduced by est. 8-10% (area)
Exhaust: Thunderbike 3 - 1
Cams: Stock
Ignitor: Stock
Ignition Pick Up: Est. 2 deg advance filed from mount holes (rotor circumference ~ .65mm / degree
Coils: Nology
Main Jets: '98' dynojet
Needle: dynojet 3rd notch from top
Float Height: 14.0 mm
Pilot Jets: 40
G/box sprocket 19 tooth
Great torque thru' whole rev range, pipes loud but great sound.
Now fitted unrestricted inlet rubbers T1240080 -
No jetting or needle changes needed, stronger in midrange than before, top end & low end as strong as before.
Torque curve feels strong, flat & smooth from ~ 1,500 rpm to redline.
Last edited by IrlMike : 02-20-2008 at 01:55 PM. Reason: Changed to deristricted inlet rubbers....
  #19 (permalink)
Old 02-15-2008
IrlMike's Avatar
Couple of things to add to my last post....
Checked my fuel economy also - 54 miles per gallon (Imp.) over 110 miles mix of slow mountain twisties & 100kmh (62mph) main roads.
Pleasantly surprised after reading test reports ~ 43mpg.
Clearly more power from improving air/exhaust flow can also mean good engine efficiency. (Probably 19t front sprocket also helps here - reccommend for 5 speeders where power mods done.)
Not sure if this fits here, but have just fitted Racetech Cartridge Emulators to forks. On Ireland's bumpy roads suspension matters, & as murphy's law has it, the worst bumps & potholes are on bends ! Cartridge emulators have made a massive improvement to brake dive & general front end control. I've kept the stock springs for now - I'm only 150lbs so no big deal. At $160 for parts (self fitted), for my weight & Ireland's roads these are easily best bang per buck of any mods I could make imho.
  #20 (permalink)
Old 02-20-2008
patrol21's Avatar
Favorite Bike: 95 TBIRD
Hey Mike,
Did you change out the rubbers or remove some of the material on the inside of the rubber? Having Mikuni's, the unrestricted rubbers for the Keihens are not a fit. I was also told that Tiger's using Mikuni's had unrestricted rubbers but i cannot confirm. Let me know.
The worst day riding beats the best day at work....no exceptions.
Jetting Whitehurst Club Cafe 4 12-24-2007 04:07 AM
D&D Jetting technogrunt Twins Technical Talk 6 03-01-2007 07:57 AM
JETTING HELP?!?!? Brooksie Twins Technical Talk 4 01-05-2007 01:07 PM
How about a member list of tuning setups? dazco Triumph Twins HangOut 9 07-28-2005 06:51 PM
possible setups Modifications & Workshop Talk 11 09-01-2003 02:42 PM
