Keihin carb vent hoses????? help
I have a 99 THunderbird. I have cleaned the carbs and put it back together. In the process I took out the California crap (hoses, valves, more hoses, and canisters). My bike is lighter now? Anyway, the vent hoses from the carbs used to go up to some solenoids above the carbs and below the gas tank.
My question is where to the carb vent hoses go on a non-California triple?
When I hooked the two vents together it would run a little while and then die. When they are open to the atmosphere, all seems well but I am not sure that it is ok to leave it that way.
