Originally Posted by gregp
From a stuck float??? C'mon.
Yep.
Liquid gasoline doesn't compress, so if you get liquid gas into a cylinder the piston will 'jam' (AKA: hydraulic lock) and bend the connecting rod.
A bent connecting rod seldom fails immediately on these bikes -- it takes anywhere from a few hundred to a few thousand miles before it breaks and rips through the side of the engine.
The hydraulic lock / later destruction syndrome was a 'known problem' on the earlier 885 Tiger models where a left side fall over allowed engine oil to enter the airbox and flow into the #1 cylinder.
Fortunately it wasn't a common problem since the engine had to have stopped on the intake cycle with the piston in the down position before it could happen and the odds were against that.
Jim
