If you're already running rich, then why consider the #42 pilots?
Cause I believe the dealer-guy-mechanic put in 45's (that's what the kid said was written on the order from last year...maybe the 5 was a 2?)So I might have 45's and at LEAST 42's- I just asked for larger pilots- I was naive enough to let him decide and I don't remember what it is- can I measure or observe?
If you put them in you're probably going to be unable to adjust the idle mixture, starting will become difficult, your mileage will drop by 5 mpg or more and you'll be fouling plugs pretty consistently.
NOW my pipe tips are black- plugs are black, when I get on it (higher rpm's the guy behind me said it looked like a lot of black smoke coming out, the next time I wound it out- the same guy said it was cleaner- as if I blew out a lot of accumulation. So I'm thinking maybe he DID do 45's...Now I get a tad under 40mpg- less if I'm real aggressive It actually starts pretty well- but hard to adjust choke thereafter to keep it from stalling.
Try testing the jet size first. Roll up over 5000 rpm on the smallest throttle possible and see if there's any bucking or if the bike feels weak. If it feels a bit feeble then go to a #40 (1.5 turns on the mixture screws) and try again. If it's better keep the #40s, if it's the same go back to the #38's.
You can try the #42s too, but you'll hear the exhaust sound go dull and you'll probably have some bucking. The mixture screws should be somewhere around 1 turn for that, but the big jets will 'swamp' the mixture adjustment anyway.
I felt some bucking today- pulling away slowly.
So for my stock air intake and slightly bigger exhausts (TORS) maybe try back to stock first?!?!
BTW, you didn't mention any other mods so I'm assuming the stock intake setup.
yup
