Old 08-28-2007   #1 (permalink)
2002 thunderbird rear disc worn out
I am just about to purchase a thunderbird with 22000km on it and the rear disc is below the service limit.It is being replaced before I get the bike but I was wondering if thunderbirds are prone to this happening?It seems odd to be worn out at 22k ?
bueller is offline   Reply With Quote
Old 08-28-2007   #2 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Not very common, often it is caused by a sticking rear caliper or badly adjusted rear brake. But it can also be caused by bad riding style.
Mick...
Old 08-28-2007   #3 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
Just a couple of other thoughts.
My Thunderbird had a slightly scored disc, and I was alarmed to see the wear when I fitted a set of sintered rear pads (only pads available, when I was in a fix). Perhaps your T-Bird has suffered something similar? (E.g. scoring and non-OEM brake pads)?
The other thought is that a "cruiser" style of an upright riding position leads to a greater use of the rear brake, as against a "sports" prone riding position. (This is related to where the weight of the rider is, and the use of the rear brake to maintain front/rear balance).
The OEM brake discs are stainless steal, so a new one (with regularly replaced/maintained pads) should last you along time.
Geoff
GeoffE is offline   Reply With Quote
Old 08-28-2007   #4 (permalink)
Its very easy to leave the tip of your toe on the peddle............not enough to notice the very slight drag,but It causes premature wear.I`ve done 30,000 miles and mine`s looking a bit thinner than I`d expect.
Petrol is offline   Reply With Quote
Old 08-28-2007   #5 (permalink)
Favorite Bike: 98 Thunderbird
I concur with Geoff. My rear disc was still like new at 20k miles, when I replaced the pads with HH parts. 5k miles later it was worn out.
Old 08-28-2007   #6 (permalink)
thanks for advice,will only be using OEM pads and I keep an eye on my foot position in relation to the lever.
Old 08-28-2007   #7 (permalink)
I dumbaxed it and couldn't figure out whose brake was smoking. Then I realized my boot was dragging on the pedal. So I adjusted it out of my way and all has been well (after I replaced maybe my 2nd set of rear pads in a lot of years of riding).
Yee-haaaaa!
front tire worn out before rear bronsonj Twins Technical Talk 25 01-15-2008 08:00 AM
Worn rear brake pads? Calzor_Suzay Sprint Forum 8 07-31-2007 06:52 PM
2002 Thunderbird Tooth Hinckley Classic Triples 12 08-23-2006 09:34 AM
rear tire worn out haggis95 Sprint Forum 10 08-17-2005 02:18 AM
