My first Triumph - a T-Bird - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario TourismHonda PowersportsNew Bonneville
Old 08-20-2007, 12:03 PM   #1 (permalink)
slowkitty's Avatar
Hiya,
Came across this forum. Just acquired a T-Bird, and I love the lines of the bike, took the plunge even though the bike is nearly 10 years old. Anything to watch out for or change before I go far on it?
Cheers
Cat
slowkitty is offline   Reply With Quote
Old 08-20-2007, 12:19 PM   #2 (permalink)
BadMouth's Avatar
Welcome aboard!
A couple questions that might affect our answer to your question:
What's the mileage on the bike?
Was it purchased from a dealership or has it been sitting unused for any length of time?
You can check the known issues sticky, but don't let it scare you.
These bikes were overengineered and very reliable.
I've put 20,000 miles on mine in the past two and a half years and the only problem I've ever had was a coil going bad. Even that didn't leave me stranded. If you ever do have a problem, you can find the answer here.
BadMouth is offline   Reply With Quote
Old 08-20-2007, 12:27 PM   #3 (permalink)
KD5QOQ's Avatar
The worst issue I've come across is that I can't stay off the thing!
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
KD5QOQ is offline   Reply With Quote
Old 08-20-2007, 10:08 PM   #4 (permalink)
slowkitty's Avatar
Thanks for the welcome. 25,000 on the clock, outlook seems fine. I was told bike was intermittantly ridden, owner sold because he wanted a more everyday bike and was spooked by the lack of spares.
There's gooey stuff around the forks, near the seals, rear shock seems tired, very tired. Good to put Ohlins and if so where to buy? Most people seems to put Hagon. Also advisable to get K&N?
Will get cracking on the "search" button, in the meantime I appreciate all the help that I can get.
Cheers
Cat
Old 08-21-2007, 11:02 AM   #5 (permalink)
BadMouth's Avatar
If you don't know the service history, I'd replace all the fluids (brake, clutch, fork oil, engine oil, coolant). You may also want to check the valve clearances.
I haven't heard of anyone installing Ohlins : on a Tbird, but I'd be interested in any information you find. Everyone in the forum seems to swear by the Hagon. Most purchase is from www.davequinnmotorcycles.com
The K&N isn't much of a performance boost on it's own, since the airflow is restricted by undersized inlet on the airbox anyway. It is however, a cheaper alternative to the OEM filter, since Triumph requires you to purchase the entire airbox just to replace the filter.
Other than that and the obvious items (tire tread, chain/sprocket wear, etc), you should be good to go for many miles.
Old 08-22-2007, 10:08 AM   #6 (permalink)
slowkitty's Avatar
Really?!!!!!!! Will just ride the bike and see what needs to be done. Best tyres?
Cheers
Cat
Old 08-23-2007, 12:04 AM   #7 (permalink)
Petrol's Avatar
I`ve had a T bird 10 years.Always use the best oil,semi synthetic at least.Use only genuine filters.tyres.............http://www.avon-tyres.co.uk/motorcyc..............but above all,enjoy
Petrol is offline   Reply With Quote
T-Bird Sport Pipes on a Standard T-Bird Readyt Hinckley Classic Triples 3 05-14-2007 09:54 AM
Will 95 thru 97 stock T-Bird seat fit on 98 T-Bird? Jeff02 Hinckley Classic Triples 3 11-30-2005 05:47 PM
Does nayone have p[hotos of their t-bird with Triumph saddlebags? jhusman Hinckley Classic Triples 14 09-03-2004 12:18 PM
T-Bird vs T-bird Sport seat Interchangeable? chadoll Hinckley Classic Triples 3 08-01-2004 03:34 PM
New Bird Hinckley Classic Triples 8 04-11-2004 01:10 PM
