Backfire at Idle - How to get plugs out?
Recently upgraded exhaust, pods, intakes, jets, pilots, raised needle. Setup at 128mains/38pilots was just a bit lean. Put 135/42 on, no idle/air adjustment...ran good for one run, without the usual popping on decel. Went to start it up today, and it backfired through the carbs as well as the exhaust, and number one cylinder not even firing anymore. Tried to pull a plug(for the first time ever) and I don't seem to have the right socket. Anyone know what the backfire means and the size I will need for the plugs?
Poke
ShikePoke - "Hated to kill the boy...but he needed to be taught a lesson..."
