Factory Pro Ignition Advance Rotor - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-15-2007, 02:29 PM   #1 (permalink)
BadMouth's Avatar
I received my ignition advance rotor from factory pro yesterday evening (Part #RTR-TRI-21-04 (+4 degrees)). The Pre-98 label on their website is total hogwash. On the label, it says "Replaces OEM #T1290110", which was the part # stamped on the OEM rotor of my 2000 model. In a previous thread, someone mentioned bikebandit having the same # rotor for all models, so I would assume the Factory Pro rotor would work on any 900 triple.
The results are going to be subjective, but I feel that it did make a LARGE improvement in throttle response. As far as the claim of added horsepower, it "feels" like I have more power, but only a before and after dyno would prove it (and I'm not paying for one). All in all, for the price of $55 and the 10 minutes it took to install it, I say it's a worthwhile upgrade.
Other info that may have come into play:
I always run the highest octane fuel anyway, so I don't know if the advanced timing would be a problem with lower octane fuel.
2000 Tbird, 955 cams, Thunderbike exhaust, K&N pod filters, S3 ignitor
BadMouth is offline   Reply With Quote
Old 08-15-2007, 02:50 PM   #2 (permalink)
Thank you so much for your impressions on the advancer. I am sure that many on this forum, like me, were waiting to hear what you had to say about it.
- Ryan
Rhinoe is offline   Reply With Quote
Old 08-15-2007, 04:36 PM   #3 (permalink)
bkline's Avatar
Good to hear, as I should be getting mine in the mail tomorrow.
1996 Cafe Adventurer Project
http://www.triumphrat.net/memberalbu.../14456/cat/500
bkline is offline   Reply With Quote
Old 08-16-2007, 08:43 AM   #4 (permalink)
Hey Bad,
Did you have to replace the gasket when you put in your new rotor?
- Ryan
Old 08-16-2007, 10:59 AM   #5 (permalink)
BadMouth's Avatar
I didn't replace it, but I had a spare on hand.
Murphy's Law states that if you don't have one on hand, it will tear and the dealership will be out of stock.
In my first post, I also should have mentioned that Factory Pro never responded to my email inquiring about whether or not the rotor might work on my 2000 model.
Where is ignition advance rotor located? svanos Hinckley Classic Triples 12 02-18-2008 09:39 PM
Ignition advance? BadMouth Hinckley Classic Triples 0 06-20-2007 05:51 PM
Factory Pro Spooner Hinckley Classic Triples 1 07-18-2005 01:27 AM
Turns out this free engine has 4 degree advance rotor in it. 00wabbit Hinckley Classic Triples 7 12-17-2004 06:22 PM
Ignition Advance Rotor Beemie Hinckley Classic Triples 0 10-11-2004 12:24 AM
