HELP!! TBS Brake Pad Replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-12-2007, 01:57 AM   #1 (permalink)
pbbeck's Avatar
I'm going to replace the brake pads and do a brake bleed on my new '98 TBS. The pads on it are shot. The shop manual I ordered won't arrive for a few days, but if I don't deal with the brakes tomorrow, I won't have time for a month, so...
Are there any torquing specs I will need to know while replacing brake pads and doing a brake bleed?
Thanks so much for any feedback.
2006 BMW R1200GS
2006 MV Agusta Brutale 910s
'98 Thunderbird Sport
My Web Site
pbbeck is offline   Reply With Quote
Old 08-12-2007, 08:13 AM   #2 (permalink)
tridentt150v's Avatar
No, if you slip the pads out after removing the locating bolts etc just do them up again.
There are probably torque settings, but you don't need them. I've never used them for this job. I just do them up firm. They all have a shoulder to locate on, so you are not preloading anything.
tridentt150v,
Great Southern Land.
tridentt150v is offline   Reply With Quote
Old 08-12-2007, 03:07 PM   #3 (permalink)
Ditto previous.Replacing front and rear pads a piece of cake. No torque settings relevent. Did mine for the 1st time a couple of months ago and it took me longer to read - up on the job in the manual than it did to do it!
Fish out of sand.
Bluestone is offline   Reply With Quote
Old 08-12-2007, 05:06 PM   #4 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Finger tight plus 1/8th of a turn on the bolts will suffice.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 08-13-2007, 01:54 AM   #5 (permalink)
pbbeck's Avatar
Thanks all. As you all said, it was a piece of cake, though without the shop manual it took a bit longer than it might have otherwise.
Overall, it was a productive weekend. On Friday, I got new tires mounted (Dunlops), and this afternoon I changed the oil and filter, bled the brakes, and replaced the pads. The rear pads were completely gone. I mean gone... only metal and two adhesive residue spots remained. The front pads had only about 1/16" remaining. I also replaced a two blown bulbs in the instrument cluster.
2006 BMW R1200GS
My Web Site
Brake pad replacement question climbbike Sprint Forum 2 06-07-2007 06:32 AM
Brake pad replacement question NotSoFast Sprint Forum 4 05-01-2007 11:15 AM
Front Brake Pad Replacement T100Aust Twins Technical Talk 8 09-04-2006 07:30 PM
Brake Pad Replacement -- Speed Four sangsters Maintenance & Workshop Talk 0 05-02-2006 09:21 PM
Brake Pad Replacement 2trumpets Hinckley Classic Triples 5 07-21-2005 03:33 PM
